trigo(at)mail.telepac.pt Guest
Posted: Fri Dec 08, 2017 4:42 pm Post subject: Rear seats seatbacks |
Guys
As you know, the rear seats seat backs have reinforcement angles in all 4 edges, 2 vertically (thicker) and 2 horizontally (thinner), and it is clear that these 4 angles are the seat backs structure.
But in the upper horizontal edge, the corrugated aluminium sheet also has a tab that goes backwards (pointing to the baggage compartment), with a tip slightly bend, and this tab goes over the upper angle.
I don’t understand what is this tab for.
The problem is that I am now beginning to upholster the seat backs, and it looks convenient to eliminate this tab.
Does anybody know what is this tab for?
Is there any problem to eliminate this tab?
Carlos
489.4 KB |
8618 Time(s) |
sportav8r(at)gmail.com Guest
Posted: Fri Dec 08, 2017 5:33 pm Post subject: Rear seats seatbacks |
A darned good question I've had since i built my -6A twenty years ago. It's done the exact same way.
My hunch is it's to finish the edge which would otherwise be wavy between the rivets, and to add a tiny bit of shear web in addition to the angle stock, to make it less flimsy. I bet it's a complete non-issue, for the loads the seat backs see in use.
On Fri, Dec 8, 2017 at 7:40 PM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
| Quote: | Guys
Carlos
Greg McFarlane
Joined: 12 Apr 2012 Posts: 58 Location: Albany Western Australia
Posted: Sat Dec 09, 2017 1:50 am Post subject: Re: Rear seats seatbacks |
Some of the after market seat makers use that angled overhang to secure the seat cover, a flap of material goes over the top and is usually secured underneath by self adhesive valcro. Gives a nice finished look to the seat back cause it carries the fabric or whatever right over the back and out of sight. Also on the RV6 and maybe others there was a strip the slot would fit into and stop the seat backs flopping forward, most builders ( that I know) not saying it’s the right thing to do, didn’t fit that strip cause sometimes it’s handy to be able to pull the seat back forward a bit to gain access to the baggage compartment. Probably the seat back design has continued cause it’s just a standard part interchangable through the models . Cheers from Western Australia
Posted: Sun Dec 10, 2017 4:26 am Post subject: Rear seats seatbacks |
Bill
In my -9A, the seats backs have a similar tab, also with a bend tip, but that tab has a clear function, which is to fit in a female slit and hold the seat back.
But in the -10 there is no slit where this tab goes in, i. e, the tab is free in the air, so I don’t see any mechanical or structural mission for it.
Carlos
Enviado do meu iPhone
No dia 09/12/2017, às 01:32, Bill Boyd <sportav8r(at)gmail.com (sportav8r(at)gmail.com)> escreveu:
| Quote: | A darned good question I've had since i built my -6A twenty years ago. It's done the exact same way.
| Quote: | Guys
Carlos
Posted: Sun Dec 10, 2017 4:35 am Post subject: Rear seats seatbacks |
Thank you Greg (in Western Australia)
for your explanations
I agree with your last assumption (that it’s probably a lazy continued design from the 2-seat models).
But to secure the seat cover, it would suffice the upper structural angle, it would not be necessary this thin aluminium sheet tab... I would say
Carlos
No dia 09/12/2017, às 09:50, Greg McFarlane <grbcmcfarlane(at)gmail.com> escreveu:
http://forums.matronics.com/viewtopic.php?p=476265#476265
Posted: Sun Dec 10, 2017 8:01 am Post subject: Rear seats seatbacks |
Carlos, I've never inspected a -9 that closely, but in the -6 models, the tab that fits into either of a pair of slots on the seat back cross-brace is attached to the seat back by hinge material several inches below the top of the seat, and is used to set the seat back recline angle. The fold at the top of the seat back serves no apparent purpose. Velcro could be attached to the angle stock about as readily as to the bent flange we're talking about. And if you sew an inverted pocket into the top of the seat back cushion, there'd be no need for Velcro attachment to hold it.
I'd say cut it off if you wish. I might very well do the same except I don't want to complicate life for Abby or whoever supplies my upholstery one day.
On Sun, Dec 10, 2017 at 7:25 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
| Quote: | Bill
Carlos
| Quote: | Guys
Carlos
Posted: Sun Dec 10, 2017 9:02 am Post subject: Rear seats seatbacks |
This is what I did
[img]cid:6F47482E-E08B-4636-8F83-0FAF1A9362A5[/img]
I didn’t cut the tab, but I bent it around the angle.
Afterwards, I covered it with the leather I glued over the front of the backrest
Carlos
No dia 10/12/2017, às 16:01, Bill Boyd <sportav8r(at)gmail.com (sportav8r(at)gmail.com)> escreveu:
| Quote: | Carlos, I've never inspected a -9 that closely, but in the -6 models, the tab that fits into either of a pair of slots on the seat back cross-brace is attached to the seat back by hinge material several inches below the top of the seat, and is used to set the seat back recline angle. The fold at the top of the seat back serves no apparent purpose. Velcro could be attached to the angle stock about as readily as to the bent flange we're talking about. And if you sew an inverted pocket into the top of the seat back cushion, there'd be no need for Velcro attachment to hold it.
| Quote: | Bill
Carlos
| Quote: | Guys
Carlos
525.99 KB |
8582 Time(s) |
