Lamp Dimmer
JOHN TIPTON
PostPosted: Fri Dec 08, 2017 1:05 am    Post subject: Lamp Dimmer Reply with quote
Hi Guys
Can someone recommend a 'dimmer' for the instrument lights, that will achieve this: three position switch - Off- On -Dim
John
----x--O--x----
argoldman(at)aol.com
PostPosted: Fri Dec 08, 2017 5:24 am    Post subject: Lamp Dimmer Reply with quote
You could always get a Lucas automobile dimmer. It has 3positions— OFF DIM and FLICKER
Rich
On Dec 8, 2017, at 3:04 AM, John Tipton <jmtipton(at)btopenworld.com> wrote:
Hi Guys
John
----x--O--x----
Eric Page
PostPosted: Fri Dec 08, 2017 10:02 am    Post subject: Re: Lamp Dimmer Reply with quote
Do you mean that you want off and two fixed brightnesses (dim and full) or do you want off and an adjustable brightness up to full?
If the former, then you just need a SPDT [OFF-ON-ON] switch and a high wattage resistor of a value that gives the brightness you desire. “Dim” goes through the switch then through the resistor, bright just goes through the switch. We can help with resistor value and wattage if you can post specifics about your installation.
If you want adjustable brightness, then Eric Jones makes/sells a linear dimmer unit here...
http://www.periheliondesign.com/egpavr.htm
Eric
