kearney
Posted: Sun Nov 12, 2017 4:27 pm Post subject: CofG Question (Sort of) |
Hi
I have my -10 project on a dolly and am planning to get it up on its wheels in the next couple of weeks.
I have the tail cone (but not the feathers) attached and am wondering how tippy it will be if there is no engine attached.
Any comments? If I need to add ballast to the nose till I get an engine, is there any preferred way to do this?
Cheers
Les
C-GROK (now officially in fiberglass hell)
C-GCWZ flying
Posted: Sun Nov 12, 2017 5:31 pm Post subject: CofG Question (Sort of) |
It’s not tippy side to side at all. You need to prop the tail up until you get the engine on. You would need several hundred pounds on the nose to hold the tail up in a stable way. I would just put a stand on the tail like in he attached picture.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
| Quote: | On Nov 12, 2017, at 7:27 PM, kearney <kearney(at)shaw.ca> wrote:
Hi
Cheers
Les
C-GCWZ flying
http://forums.matronics.com/viewtopic.php?p=474863#474863
373.01 KB |
9369 Time(s) |
Lew Gallagher
Joined: 04 Jan 2008 Posts: 402 Location: Greenville , SC
Posted: Sun Nov 12, 2017 6:27 pm Post subject: CofG Question (Sort of) |
Hey Les,
I needed to maneuver the plane w/out wings or tail feathers in and out of
the shop during painting and w/out the engine. So I lashed two 5 gal. jugs
of water onto the engine mount to counter the tail. It was just enough so
that I could push down on the tail to raise the front wheel ... easily
steered it from the tail. Used a small prop under the tail tie down so
that I could temporarily install the vert and rudder to tape off stripes
matching the fuse.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
gspecketer(at)gmail.com Guest
Posted: Mon Nov 13, 2017 6:27 am Post subject: CofG Question (Sort of) |
It is tail heavy about 15 lbs
GARY Specketer
Hi
Cheers
Les
C-GCWZ flying
kearney
Posted: Mon Nov 13, 2017 8:28 am Post subject: Re: CofG Question (Sort of) |
Guys
Thanks for the info. I'll likely install bump bar in tail but use the water in pail trick as well.
Cheers
Les
Albert Gardner
Posted: Mon Nov 13, 2017 10:47 am Post subject: CofG Question (Sort of) |
Well, if it isn't one thing it's another. Last week my Garmin 496 GPS died,
this week it's my HID landing lights. So I'm going to replace them with
LEDs. Vans sells a Sunspot LED wing tip kit for the RV10/14 kits. From the
picture I can't tell if they are a exact replacement for the original RV-10
wing tip landing light or not. Vans picture doesn't show the position lights
that the original installation has in the wing tip. Maybe there is a better
LED light available. Wouldn't mind installing them inboard from the tips for
better center line coverage. I've considered an additional light under the
prop for center line coverage. Tried mounting one on the front wheel pant
but too much vibration for a filament type lamp. LED should be ok with
vibration though. Any landing light suggestions?
Albert Gardner
RV-10 N991RV
Yuma, AZ
RV-10 N991RV |
Tim Olson
Posted: Mon Nov 13, 2017 11:07 am Post subject: CofG Question (Sort of) |
I can't comment on most of the things in the email, but
I can tell you that a bit over a year ago I bought a set
of HID's on ebay, brand new, and the pair of them with
ballasts was about $110. So, if you do end up wanting
to replace your HID with another HID, the cost is
probably much less than your original purchase. I think
I paid $400 each back in 2005, and now they're more like
$110/pr if you find them right.
I'm assuming your HID is mounted in a wing cutout.
You should be able to find an LED that will fit into
that spot too, but you'll spend a bunch more...but you
can get a real good light too.
Tim
On 11/13/2017 12:45 PM, Albert wrote:
Albert Gardner
RV-10 N991RV
Yuma, AZ
Kelly McMullen
Posted: Mon Nov 13, 2017 12:26 pm Post subject: CofG Question (Sort of) |
Just leave the pail of water outside overnight and you will have a solid weight. ;-(-sent from the I-droid implanted in my forearm
On Mon, Nov 13, 2017 at 9:28 AM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
| Quote: | --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Guys
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=474945#474945
WIKI -
A&P/IA, EAA Tech Counselor
KCHD |
