Housai Engine Needed
Top Ace
PostPosted: Thu Nov 09, 2017 1:53 pm    Post subject: Housai Engine Needed Reply with quote
If any one has a HS6A engine sitting for sale, let me know, David
woodja51
PostPosted: Tue Dec 05, 2017 2:53 pm    Post subject: Re: Housai Engine Needed Reply with quote
Hi David , I might be interested in selling a spare HS6 I have .
I would need to get close to 20k for it as they cannot be purchased from China anymore without much difficulty. Mine has around 300 hour on it since factory overhaul. It blew a supercharger so all thr cylinders have been pulled , honed and valves lapped to bring it back to spec . The bottom end and gearbox is all
Clear ( nothing went thru thr bottom end as the filter got thr small bits . New oil pump , air starter , mags all timed , new urethane engine mounts , rocker gaskets from Doug , new plugs , aft accessory drive and blower all replaced from a low time spare engine (all logs for both available ) . It’s on a mounting pallet ready to basically test run but as I don’t need it yet my engineers tell me not to test run it due to preservation need afterward. If you’re interested let me know . I’m in Melbourne - Australia so shipping might be a few K .
Cheers , Matt +61420347885 mwuillemin(at)mac.com
 Filesize:  2.44 MB
 Viewed:  5431 Time(s)
Chrisw
PostPosted: Sun Feb 18, 2018 5:08 pm    Post subject: Re: Housai Engine Needed Reply with quote
Hi David,
My name is Chris Walker. I've just swapped out my Housai for an M14P. Please call me at 1 (250)882-1895 if interested.
807 hrs TSOH, 1400 hrs TTSN
I'm in Victoria BC, Canada
