firestar503
Posted: Sat Nov 04, 2017 8:13 pm Post subject: Wing support dolly |
Hi Kolbers,
Over the years I’ve seen several ideas posted for permanent cradles for mounting the wings and tail on castor wheels for easy moving about when folded or partially folded. Does anyone have plans, pictures or know where the subject can be researched?
JonL
Firestar II
The Kolb-List Email Forum -
Navigator to browse
List Un/Subscription,
7-Day Browse, Chat, FAQ,
- MATRONICS WEB FORUMS -
via the Web Forums!
- NEW MATRONICS LIST WIKI -
Email List Wiki!
- List Contribution Web Site -
support!
RoHam
Posted: Sun Nov 05, 2017 6:03 am Post subject: Re: Wing support dolly |
I have this one photo of a boom/wing caster assembly. I'd like to see a tailwheel hook for moving the plane when the wings are folded.
94.85 KB |
14949 Time(s) |
RoHam
Posted: Sun Nov 05, 2017 6:14 am Post subject: Re: Wing support dolly |
A buddy of mine uses these cradles that he purchased at Harbor Freight for short money. He has one also on tail wheel, which allows for movement in any direction. Sorry for large photo. I'm not sure how to shrink it.
2.5 MB |
14941 Time(s) |
Richard Pike
Posted: Sun Nov 05, 2017 4:33 pm Post subject: Re: Wing support dolly |
Vince designed this for his FSII, we are using it on the FF, and it works good. A little explanation is in order: the two 1x4's lay on either side of the lower fin, and above the tail wheel, including above the arms that come out at the base of the rudder. The rest of it extends foreward so that the 2x4 with the castors on it is about even with the forward end of the vertical fin.
Notice the rope that goes through one of the 1x4's about half way along: the rope goes through the opening just behind the aft fuselage ring where the elevator and rudder horns are, goes down to below the lower fin, and back up where it is passed through the rope loop and tied off to secure that section.
Up at the front end, there is carpet to pad things, you also lay carpet over the boom tube and tie that all together with a rope wrapped around it.
The two ends of the 1x4's stick out the back beyond the rudder a bit and you can use them to pick up the tail of the airplane or guide it around. The aft ends of the 1x4's have carpet padding on the inside to protect the fabric on the lower fin and the rudder.
It is a bit tricky to get it in place the first few times, especially by yourself, but it works good once the airplane is tied to it. And when you fold the wings, it keeps the leading edges up away from the ground.
You do want to have the horizontal stab tied up alongside the vertical fin before you start trying to get the dolly into position.
220.27 KB |
14907 Time(s) |
224.7 KB |
14907 Time(s) |
206.65 KB |
14907 Time(s) |
213.96 KB |
14907 Time(s) |
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Richard Pike
Posted: Sun Nov 05, 2017 4:48 pm Post subject: Re: Wing support dolly |
| RoHam wrote: | | <snip> Sorry for large photo. I'm not sure how to shrink it. |
No problem, apparently Windows 10 no longer includes the ability to resize pictures, so you are not alone.
Fortunately there is a (free) fantastic user friendly image program that will do that and about everything else:
http://www.irfanview.com/
Kingsport, TN 3TN0
woody
Posted: Wed Nov 15, 2017 6:06 pm Post subject: Re: Wing support dolly |
I don't have plans, but I have a fine boom dolly that I put together a few years back. I don't have a picture available but will take some, along with measurements when I get over to my hanger, tomorrow I hope.
Mike Welch
Posted: Thu Nov 16, 2017 11:42 am Post subject: Wing support dolly |
| Quote: | Here is what I built a long time ago. The second picture shows it being built and before paint and upholstery. The round hinged tube is an 8” diameter PVC water pipe given to me by our local water department. (They give away short pieces). The wing supports rock back and forth to allow for full support of the leading edge. The wheels are Harbor Freights. The upholstery is heavy duty fabric, foam and a hot glue gun.
Mike Welch
[img]cid:EACD94F7-0D41-450F-B533-5D1ADF6CC3DF[/img]
[img]cid:E2E26A45-2B5D-42E8-B1CB-A234EC6B7C46[/img]
Mike Welch
834.17 KB |
14773 Time(s) |
826.61 KB |
14773 Time(s) |
Mike Welch
I made these for the front wheels.
Mike W.
[img]cid:3AA0F59F-F2C7-4085-8A27-F351E220A02A[/img]
638.52 KB |
14773 Time(s) |
Mike Welch
Posted: Thu Nov 16, 2017 11:43 am Post subject: Wing support dolly |
Mike Welch
Mike Welch
834.17 KB |
14773 Time(s) |
826.61 KB |
14773 Time(s) |
victorbravo(at)sbcglobal. Guest
Posted: Thu Nov 16, 2017 12:04 pm Post subject: Wing support dolly |
That's pretty darn nice !!!!
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net - winning proposals for non-profit and for-profit entities
On Thu, 11/16/17, Mike <mdnanwelch7(at)hotmail.com> wrote:
Subject: Re: Re: Wing support dolly
To: "kolb-list(at)matronics.com" <kolb-list(at)matronics.com>
Date: Thursday, November 16, 2017, 11:42 AM
glue gun.
Mike Welch
Mike Welch
