Yak 52 weight and balance after avionics removal
fishface68
PostPosted: Tue Oct 24, 2017 10:17 am    Post subject: Yak 52 weight and balance after avionics removal Reply with quote
Hi All,
To comply with the EASA requirement to steal our VHF bandwidth, here in europe and to sell it to mobile phone companies at a huge profit, I am in the process of organising the fitting an 8.33 KHz radio to my Yak 52.
My question relates to the removal of the Comm radio, ADF kit and associated hardware from the avionics bay and the effect of the weight and balance. Has anyone out there done this and what effect does it have on the weight and balance?
Many thanks
Regards Pat
Looigi
PostPosted: Tue Oct 24, 2017 9:46 pm    Post subject: Re: Yak 52 weight and balance after avionics removal Reply with quote
Hi Pat,
Our yak-52 has had the ADF and associated equipment removed. In their place is an ELT and an altitude encoder (minimal weight). Otherwise he is all standard with the Russian Baklan radio etc.
Our CofG is right on the forward limit, and anything we put on board (people, fuel etc) pushes the CofG back. Our empty weight (with oil, air and other essential flight equipment) is 1007kg.
I hope this helps you dude.
Chris
JuliaScott
PostPosted: Fri Jul 12, 2019 6:42 am    Post subject: Re: Yak 52 weight and balance after avionics removal Reply with quote
An electronic is here for the identification of the goals for the humans. The stuff is calculated for the movement of the essayhave reviews for all ideal paths for the humans. The picture is ensured for the satisfaction of the parts in life.
