Mounting Holes for B&C Fuse Blocks
kboatright1(at)comcast.ne
PostPosted: Sat Oct 21, 2017 7:36 am    Post subject: Mounting Holes for B&C Fuse Blocks Reply with quote
What size screw/bolt fits the mounting holes in the B&C fuse blocks? The
drawings on the website omit that detail.
Kyle Boatright
PostPosted: Sat Oct 21, 2017 9:18 am    Post subject: Re: Mounting Holes for B&C Fuse Blocks Reply with quote
The text says, "ships with #10-32 hardware".
http://www.bandc.aero/fuseholder6-slot.aspx
Make sure that the fuse block has enough slots. Here are possible loads:
SPARE, FANS, SPARE, AUTOPILOT, CAPACITOR, PCB, AUDIO, TRIM, GPS, LNDG LT, START, FUEL Press, OIL PRESS, INTERCOM, X-PONDER, RADIO, EFIS, ALTERNATOR, ADS-B, NAV LIGHTS
Joe Gores
JOHN TIPTON
PostPosted: Sat Dec 09, 2017 7:45 am    Post subject: Re: Mounting Holes for B&C Fuse Blocks Reply with quote
The text says, "ships with #10-32 hardware". --- But they don't ---
art(at)zemon.name
PostPosted: Sat Dec 09, 2017 8:48 am    Post subject: Mounting Holes for B&C Fuse Blocks Reply with quote
The aviation aisle at TruValue has what you need.
    -- Art Z.
Sent from my phone. Please excuse brevity and bizarre typos.
On Dec 9, 2017 10:05 AM, "JOHN TIPTON" <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)> wrote:
--> AeroElectric-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)>
PostPosted: Sun Dec 10, 2017 10:20 am    Post subject: Mounting Holes for B&C Fuse Blocks Reply with quote
At 09:45 AM 12/9/2017, you wrote:
--> AeroElectric-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com>
It's been a few years but If I recall correctly,
that's an 'echo' of the Bussman literature describing
the fuse block . . . and it refers to the wire
attach post on the end of the bus bar . . . not
the hardward that attaches to the aircraft.
