Kitlog
jaybhansen
PostPosted: Fri Sep 22, 2017 8:37 am    Post subject: Kitlog Reply with quote
I understand that the owner has had a stroke. I wish the best. But in the meantime, has anyone taken over Kitpro? I had issues with windows 10 for a couple of months, but the fix was posted on the Kitlog page (thanks). Now, I can't load my database and I am getting no response from Kitlog emails and/or phone calls. Does anyone have any information?
rleffler
PostPosted: Fri Sep 22, 2017 10:57 am    Post subject: Kitlog Reply with quote
It probably requires an older version of .net. I'm not at home or I would look it up.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Bob Orre <s51flyer(at)wi.rr.com>
Sent: Friday, September 22, 2017 1:20:25 PM
Subject: RE: Kitlog
I had similar login issues with Windows 10 each time MS pushed a W10 update. I followed Matt's instructions in the attachment each time Kitlog couldn't load the DB after a W10 update. It's worked twice for me. Seems to be a conflict with .NET Framework. I made sure to copy the DB, twice, just in case.
Note, this was based upon my specific reported issue of Kitlog simply not loading and giving the following error:
I am using W10, 64bit.
Bob O.
 Filesize:  6.41 KB
 Viewed:  7759 Time(s)
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
Site Admin
PostPosted: Fri Sep 22, 2017 11:09 am    Post subject: Kitlog Reply with quote
Simple fix for this. Look at Q1/A1 here:
http://www.kitlog.com/Windows10
At 11:55 AM 9/22/2017 Friday, you wrote:
[quote]It probably requires an older version of .net. I'm not at home or I would look it up.
Get Outlook for iOS
Subject: RE: Kitlog
[img]cid:7.1.0.9.2.20170922120700.0eb2e2e8(at)matronics.com.1[/img]
Bob O.
 Filesize:  6.41 KB
jaybhansen
PostPosted: Tue Sep 26, 2017 7:29 am    Post subject: Re: Kitlog Reply with quote
Upon some digging, I found out that I still had .net 1.1. When I installed version 3.5, I could open and load my database. However, not I find that I can't upload to my builders webpage. Any ideas there?
jaybhansen
PostPosted: Mon Oct 02, 2017 9:17 am    Post subject: Re: Kitlog Reply with quote
Well for some reason, I can now update. Now I have two different DB's on line. Any idea how I can delete the bad one? It only has a partial DB.
