Battery Load Testing
PostPosted: Sun Sep 10, 2017 6:31 am    Post subject: Battery Load Testing Reply with quote
At 11:20 AM 9/9/2017, you wrote:
A few weeks (?) ago, Bob posted a link to a Harbor Freight 500 Amp Carbon Pile Load Tester:
https://www.harborfreight.com/500-amp-carbon-pile-load-tester-91129.html
I thought that this is what we would use to annually test the capacity of our batteries. I thought that we would connect the battery, set the amps to our expected load (for example, 12 amps) and then time how long until battery voltage reaches an unacceptably low level.
But, upon reviewing the user manual for this tool, it does not look like that is what this thing is for. It appears to just load the battery for a short period of time and then extrapolate the battery condition based on how it behaves for that very short test period.
What's the deal? How do we use this tool to check on our battery condition, annually?
It is one of TWO tests, and the least $time$ consuming
of the two. There are two qualities of a battery that
described its performance. One is internal resistance,
the ability to DELIVER what ever energy is contained
to the outside world. This quality goes to getting
the engine started and is loosely linked to overall
quality of the battery . . . a battery whose internal
resistance is rising is loosing active material . . .
active material is directly related to the second
quality of interest: CAPACITY.
To capcheck a battery, you need to literally run
it down with some load that approximates your
anticipated ENDURANCE requirements. Then track
how many minutes that load is supported. There
are test sets that do this automatically and give
you data plots.
Here's one such device
http://tinyurl.com/mas7ea9
I've had these in the shop for over a decade.
Very handy. This tool produces data plots like
this:
[img]cid:.0[/img]
This was a new battery in installed in Dr. Dee's Saturn
just over two years ago. With a 5a load, it produced
just over 32 a.h. of energy output. I just replace that
battery yesterday . . . it had suffered a couple of run-down-
and-sit events . . . the worst thing you can do to a
battery. The new one is sitting in the garage with
a Battery Tender on it like my lab batteries.
The HF load tester is the quick'n dirty battery evaluator.
When you install a NEW battery. Make sure it's topped off
(Go flying for an hour). After landing, put the load tester
on, start the timer (15 seconds) and quickly crank the
knob up until the voltage FALLS to 9 volts. Adjust the
knob to maintain the 9v reading until the timer light
goes out. Then quickly observe and record the CURRENT
being delivered.
Repeating this test at intervals will reveal a slow
decline in that current reading. When it falls to 75%
of new, then about 1/4th of the battery's chemistry
has become inactive.
Now, if you subscribe to the legacy notion of replacement
at 75-80% of new capacity, then you know when to do it
based on this admittedly coarser measurement.
But if you'd care to do a ground check on ENDURANCE
then you need something like the West Mountain Radio
instrument -OR- you simply set up an ENDURANCE mode
load scenario in the hangar and watch a voltmeter. When
the voltage drops to 11.0 volts the battery is 90+
percent used up. If that TIME does not meet our exceed
your personal design goals for alternator-out operations,
THEN is when you replace the battery.
 Filesize:  124.96 KB
 Viewed:  4086 Time(s)
rnjcurtis(at)charter.net
PostPosted: Sun Sep 10, 2017 7:12 am    Post subject: Battery Load Testing Reply with quote
being delivered.
               HF has a slightly different approach to this test.
               Are there pros and cons of either method?
               Roger
PostPosted: Sun Sep 10, 2017 9:03 am    Post subject: Battery Load Testing Reply with quote
being delivered.
HF has a slightly different approach to this test.Â
One could debate that for a long time. This
is comparative test . . . How much does
test #2 depart from test #1? Then test #3,
#4, etc.
Use any protocol that pushes the battery to
the edge of its performance capability and
keep track of results.
