Pitch Trim tuning
trigo(at)mail.telepac.pt
PostPosted: Sat Sep 09, 2017 3:27 am    Post subject: Pitch Trim tuning Reply with quote
I am now in the process of final installation and testing the Elevator Trim system, and I could not find enough information on this.
Especially for those who finished building and are already flying, you probably already heard this question a thousand times, so please forgive hearing it once more.
When lowering the Pitch trim tabs, both go down simultaneously and both reach the bottom limit at the same time and angle.
But when they go the other direction, i.e trim tabs up, the right side tab goes till the limit but the left trim tab doesn’t. It goes up slower than the right tab, then stops moving and even reverses the movement, not reaching the upper angle limit.
Is this normal?
I did check all the Pitch trim system components, and they all seem to be installed by the plans.
Need help!
Carlos
Lew Gallagher
PostPosted: Sat Sep 09, 2017 4:42 am    Post subject: Pitch Trim tuning Reply with quote
Hey Carlos,
I saved this from years ago. VERY common problem. I’ll attach as a PDF file.
Later, – Lew
Sent: Saturday, September 09, 2017 7:25 AM
Subject: Pitch Trim tuning
Is this normal?
Need help!
Carlos
El_trim.pdf
 Filename:  El_trim.pdf
 Filesize:  43.31 KB
 Downloaded:  603 Time(s)
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
Lenny Iszak
PostPosted: Sat Sep 09, 2017 5:14 am    Post subject: Pitch Trim tuning Reply with quote
Tim has an excellent writeup on his site explaining the issue and how to fix it:
http://www.myrv10.com/N104CD/maintenance/20080622/index.html
It just recently saved my sanity trying to align my trim tabs after a trim bellcrank rework.
Lenny
On Sep 9, 2017, at 7:25 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
<![endif]--> <![endif]-->
Is this normal?
Need help!
Carlos
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs
Kelly McMullen
PostPosted: Sat Sep 09, 2017 3:10 pm    Post subject: Pitch Trim tuning Reply with quote
Excellent. I just did Bill's procedure to verify my trim. No need for digital level, nothing but Mk 1 eyeballs and a small ruler.
'My left tab was fine, my right tab needed one turn of adjustment. So I guess I will gain 5 kts on next flight. ;^)
-sent from the I-droid implanted in my forearm
On Sat, Sep 9, 2017 at 5:40 AM, <lewgall(at)charter.net (lewgall(at)charter.net)> wrote:
Hey Carlos,
Later, – Lew
Is this normal?
Need help!
Carlos
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Bob Turner
PostPosted: Sat Sep 09, 2017 4:14 pm    Post subject: Re: Pitch Trim tuning Reply with quote
Not what you asked, but...
Most people find the stock trim speed about right for airspeeds less than 100 knots. For higher airspeeds it's nice to have a way of slowing the trim speed down.
Bob Turner
RV-10 QB
PostPosted: Sun Sep 10, 2017 10:35 am    Post subject: Pitch Trim tuning Reply with quote
Thank you Lew and Lenny
I will try to follow the documents you both sent/pointed me out, and see if I reach the right rigging.
But judging by what’s written on them, it seems that the correct position of the FULL NOSE DOWN is that the Right Tab is up (23-25 degrees) and the Left Tab is neutral, which seems odd to me.
It would appear that this position would cause some “distortion” to the tail ….!!?
What are everybody’s thoughts on this?
Carlos
De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Lenard Iszak
Enviada: Saturday, September 9, 2017 2:13 PM
Para: rv10-list(at)matronics.com
Assunto: Re: Pitch Trim tuning
Lenny
Is this normal?
Need help!
Carlos
Lenny Iszak
PostPosted: Sun Sep 10, 2017 11:01 am    Post subject: Pitch Trim tuning Reply with quote
Keep in mind that other RV models have only one trim tab.
What causes distortion is that at one point you can have one tab trimming up while the other is trimming down.
On Sep 10, 2017, at 2:33 PM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Carlos
De: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] Em nome de Lenard Iszak
Para: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
Lenny
Is this normal?
Need help!
Carlos
Lenny Iszak
Palm City, FL
