Engine Oil Ring Fush
Jim Combs
PostPosted: Tue Aug 15, 2017 5:47 am    Post subject: Engine Oil Ring Fush Reply with quote
I am running a Lycoming IO540-C4B5 on my 10.  At the last condition inspection, the number one and two cylinders failed the compression test with numbers of 58/80.   To date it now has about 750 additional hours on it over six years of flying.
A little history.  I put this engine on the airplane in 2009 with a first flight in 2010.  It had 982 SMOH and had all chrome cylinders.  I had the fuel system overhauled and added a light speed ignition on installation.  After some running, I replaced three of the cylinders (1 and 2 were in that three).  Over the next five years of operation two more cylinders were replaced.  Looking back at the condition inspections I see that the compression numbers on 1 and 2 were steadily dropping by about 5 points per year.  Had not really noticed anything until these two failed.  Oil consumption took a large hike just before the last condition inspection too.  So now I was looking for a problem.
I had resigned myself to remove those two cylinders and see what was going on.  Bore scope inspection showed the valves to be OK.  I had the cowling off and was getting ready for a removal and got a visit from another pilot on the airport who has a long history of flying and racing IO-540 engines and currently flies a Piper Malibu (Twin turbo IO-540 engine).  After talking with him, he suggested I do an oil ring wash on the two cylinders using the procedure in the attached document.  He said it had saved two engines in the past and that he now does this on the Malibu at each annual.  So what the heck, I had nothing to loose by trying this.
After doing the oil ring wash, changing the oil, and and flying for a couple of hours, I checked the cylinders again.  78/80 on both cylinders and oil consumption is back to low numbers.
Engine is running great now (35+ hours) and at the next condition inspection I will do the other four cylinders.
So my question: Has anyone ever heard of this?  I was very skeptical but the results have been way beyond my expectations.
Jim Combs
N312F
Aviation_Oil_Ring_Solvent_flush_20160114.pdf
 Filename:  Aviation_Oil_Ring_Solvent_flush_20160114.pdf
 Filesize:  83.2 KB
 Downloaded:  602 Time(s)
RV-10 -> N312F - Flying as of 12/2008
Kellym
PostPosted: Tue Aug 15, 2017 6:42 am    Post subject: Engine Oil Ring Fush Reply with quote
You need to explore further what a compression test is and isn't.
There is no such thing as "failing" a compression test if there is not
leakage through the valves. While you may have suffered some oil ring
sticking that would account for oil consumption. Your compressions are
not the issue that you think. You likely would have seen an improvement
just from flying and testing compression while cylinders were hot.
Mike Busch has some articles on the web on the issue.
Kelly
trying this.
Jim Combs
N312F
Kelly McMullen
KCHD
Jim Combs
PostPosted: Tue Aug 15, 2017 8:46 am    Post subject: Engine Oil Ring Fush Reply with quote
I had major leakage into the crankcase during the compression testing on those two cylinders.  It was not there in previous condition inspections.
I did my follow on compression testing at the same conditions as well.  So whatever this has done has resulted in significant improvement.
I do oil analysis as well.  It will be interesting to see what shows up in the next oil change analysis.
Jim C
On Tue, Aug 15, 2017 at 10:41 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
 You need to explore further what a compression test is and isn't. There is no such thing as "failing" a compression test if there is not leakage through the valves. While you may have suffered some oil ring sticking that would account for oil consumption. Your compressions are not the issue that you think. You likely would have seen an improvement just from flying and testing compression while cylinders were hot.
Kelly
Jim Combs
N312F
WIKI -
Tim Olson
PostPosted: Tue Aug 15, 2017 8:47 am    Post subject: Engine Oil Ring Fush Reply with quote
Kelly,
I'm just wanting to clarify and interpret your reply.
I for one read Jim's post and thought about it a little and
thought "man, this could actually be a good tip for
an older engine". But, to make sure the whole world knows,
let me state, "I am no expert!". I just picture it being
perhaps a good thing if you de-gum the rings and cylinder
at some point if you have high oil consumption. Maybe it's
not, and maybe I'm being led down a rabbit hole. But, if
someone were to do the procedure he attached, I would think
that if done carefully it should be a fairly non-issue,
and if it worked, could be a positive thing.
Then, to your point about compression, I do personally
understand that, and would myself just have flown it
another bit of time to see if the compression improved.
I would also make sure to do the test while warm/hot.
So I agree with your reply from that standpoint.
That said, he did see decreasing compression in steps,
so perhaps there is something that could have benefited
the engine from the procedure.
I just can't separate wives tale from truth on this
particular issue. I can see how it may be worth the
effort....if done carefully...but not sure I'm game
for doing it myself at this point. I certainly won't
throw the email away however, because I would try this
before I bought a top overhaul if the valves were good.
If you have more comments, Kelly, I'd love to have you
expand on the topic.
Tim
Kelly
> for a problem.
> Jim Combs
> N312F
Lenny Iszak
PostPosted: Tue Aug 15, 2017 9:23 am    Post subject: Re: Engine Oil Ring Fush Reply with quote
It looks like this flush method, or rather a similar one with added MEK was developed by Ed Kollin, the developer of Camguard. I trust Ed's judgement on that, and it looks like Mike Busch endorses him too.
Attaching a pdf with his method, note the warning on the bottom, that the flush might soften the oil quickdrain o-ring.
Lenny
Tim Olson wrote:
Kelly,
Tim
Kelly
> for a problem.
> Jim Combs
> N312F
Oil control ring solvent flush procedure (Ed Kollin, CamGuard).pdf
 Filename:  Oil control ring solvent flush procedure (Ed Kollin, CamGuard).pdf
 Filesize:  95.75 KB
 Downloaded:  1139 Time(s)
Kellym
PostPosted: Tue Aug 15, 2017 7:06 pm    Post subject: Engine Oil Ring Fush Reply with quote
Tim,
I don't doubt that any procedure that manages to free stuck rings will
improve both oil consumption and compression. I really wasn't commenting
on the effectiveness, short or long term of such a procedure.
What I was commenting on is the unreliability of compression tests...a
position that has been advocated by both Continental and Mike Busch for
some time. Continental has proved that an engine that only tests at
30/80 due to large ring gaps, absent valve problems will make full rated
power. Far too many cylinders are removed for "repair" that are not
justified. Yes, they make get better compression with a hone and fresh
rings, but at what cost? Does it do anything but marginally improve oil
consumption? How much oil can you buy compared to cost of removing,
repairing and re-installing said cylinder?
Kelly
On 8/15/2017 9:47 AM, Tim Olson wrote:
Kelly,
Tim
> were hot.
> Kelly
>> for a problem.
>> Jim Combs
>> N312F
Kelly McMullen
KCHD
