Analog electric clock with a relay circuit for battery capac
rnjcurtis(at)charter.net
PostPosted: Tue Aug 08, 2017 3:28 pm    Post subject: Analog electric clock with a relay circuit for battery capac Reply with quote
Some time ago you posted a simple circuit for doing an approximation of battery capacity.  The circuit consisted of an analog electric clock to measure the time required to discharge a battery, through a light bulb, down to 10 volts.  I would like to build one of these to use as an annual battery condition test.  Can you direct me to where I might find information on how to make one?
Roger
PostPosted: Tue Aug 08, 2017 5:12 pm    Post subject: Re: Analog electric clock with a relay circuit for battery c Reply with quote
http://www.aeroelectric.com/articles/battest.pdf
Or an easier way is to turn on the landing light or "Clip a 55w head-lamp bulb across the battery and come back in 2 hours to check the voltage. If it's not at 11.0 volts or above, the battery is toast."
Go to
https://www.matronics.com/archive/archive-get.cgi?AeroElectric-Archive.digest.vol-lv
and search (CTRL-F) for "toast"
Joe Gores
