Flap Position #2
Bill Crowley
PostPosted: Tue Aug 01, 2017 8:18 am    Post subject: Flap Position #2 Reply with quote
Hello, I purchased my Allegro 2000 to learn to fly in it, and have enjoyed every minute of it! However, as I live in Colorado I have had very little interaction with the other Allegro owners. My CFI generally trains in a Piper Cherokee and has had no previous experience in light sport aircraft.
Everything is coming along fine, but my CFI is a bit hesitant about using flap position #2. I would appreciate any input from other Allegro pilots about landing with flaps in position #2. What speeds do you maintain on approach, do you use position #2 in headwinds and/or crosswinds? What other advice do you have for mastering this amount of flaps?
Thank you
Bill
N50625
Brian Carpenter
PostPosted: Tue Aug 01, 2017 9:34 am    Post subject: Flap Position #2 Reply with quote
I also learned to fly in an allegro 2000. My flight instructor was just the opposite everything was full flap, stall it in landings.
I found it extremely difficult to land as the plane being so light It had absolutely no inertia at landing and your control inputs did little.
After hours and hours and hours I finally got to where I could land that way. But was never comfortable with it. I then started reading on a CT forum about landing with minimum flaps and about 2500 to 2800 rpm and my landings became much more consistently Smooth. After you get very comfortable with one flap landings then I would move on to two flaps that you might use in very short field and emergency situations. Talk about putting out the barn doors with position number two.. I still approach at about 60 mph but the angle to maintain the speed is severe.. it makes the flare and round out extremely difficult. But it certainly will land in a very short distance. As an emergency procedure you should become comfortable with doing it but I would not recommend it as routine.
Brian
Sent from my Brian's
iPhone
Thank you
Bill
N50625
http://forums.matronics.com/viewtopic.php?p=471399#471399
BRIAN N3081X
N456TS
PostPosted: Tue Aug 01, 2017 12:30 pm    Post subject: Re: Flap Position #2 Reply with quote
Hi.
I've attached the Allegro flight training supplement out of my POH. I hope it can help. It's 26 pages in total. Due to the attachment limitations here, I've broken it up into 4 PDFs.
You should be able to land well with no flaps, #1 flaps, and #2 flaps before you meet a DPE. You'll see me landing with full flaps quite a bit. In fact, if you're not good at landing with full flaps, an engine out situation will be difficult. So, don't allow the CFI to skimp on teaching every aspect of the Allegro. It's for your benefit and safety. Ideally, being able to dead stick every landing (As the situation allows).
Attached is PDF #1 of 4 (Allegro Training Supplement 1to7.pdf)
Attached is PDF #2 of 4 (Allegro Training Supplement 8to14.pdf)
Attached is PDF #3 of 4 (Allegro Training Supplement 15to20.pdf)
Attached is PDF #4 of 4 (Allegro Training Supplement 21to26.pdf)
Allegro Flight Training Pages 21 to 26 of 26
 Filename:  Allegro Training Supplement 21to26.pdf
 Filesize:  2.12 MB
 Downloaded:  1126 Time(s)
Allegro Flight Training Pages 15 to 20 of 26
 Filename:  Allegro Training Supplement 15to20.pdf
 Filesize:  2.62 MB
 Downloaded:  1002 Time(s)
Allegro Flight training Pages 8 to 14 of 26
 Filename:  Allegro Training Supplement 8to14.pdf
 Filesize:  2.43 MB
 Downloaded:  985 Time(s)
Allegro Flight Training Pages 1 to 7 of 26
 Filename:  Allegro Training Supplement 1to7.pdf
 Filesize:  2.61 MB
 Downloaded:  981 Time(s)
N456TS
hgmckay
PostPosted: Tue Aug 01, 2017 2:47 pm    Post subject: Flap Position #2 Reply with quote
Bill this is Hugh McKay I asked you to give me a call about 7:30 this evening I've been delayed and will not get back until later late in the evening call me tomorrow sometime
Sent via the Samsung Galaxy S™ II Skyrocket™, an AT&T 4G LTE smartphone.
-------- Original message --------
Subject: Allegro-List: Flap Position #2
To: allegro-list(at)matronics.com
CC:
--> Allegro-List message posted by: "Bill Crowley" <bill80132(at)msn.com>
Thank you
Bill
N50625
_-============================================================
_-=          - The Allegro-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?Allegro-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=              - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-=   --> http://wiki.matronics.com
_-=             - List Contribution Web Site -
_-=  Thank you for your generous support!
_-=                              -Matt Dralle, List Admin.
_-=   --> http://www.matronics.com/contribution
