Hi Oil temp
Flibob
PostPosted: Tue Jul 11, 2017 2:06 pm    Post subject: Hi Oil temp Reply with quote
I bought a new CJ. My first airplane oil temp always pretty much stayed around 50 to 60°. On the new plane run 7075 and sometimes a little higher. If I open the gills and lower the cylinder head down to to 120 the oil temp will stay around 70 but I don't like run the cylinder head that low the new plane is using shell 50W weight and my old plane is using Phillips multigrade any suggestions
wlannon(at)shaw.ca
PostPosted: Tue Jul 11, 2017 4:07 pm    Post subject: Hi Oil temp Reply with quote
The first thing to consider with a CJ oil temp. question is are you reading
oil IN or oil OUT?
Since it is your second CJ I'm sure you are familiar with the system but
it's possible the switch is incorrectly wired or installed.
Check switch in flight and/or compare with your GIB. Rear gauge is Oil IN.
Walt
cjpilot710(at)aol.com
PostPosted: Tue Jul 11, 2017 6:12 pm    Post subject: Hi Oil temp Reply with quote
I am no expert. I've used Aeroshell 100W in both the HS6 and M14p in my CJ. Anytime I used a multi grade in either engine, I notice oil leaks. I've notice the same thing on PW 1830 on our B24. We no longer use multi grade on either the B-17 or B-24. 50w seem a little light for these engines.
Make sure your oil cooler is clean. I use a mixture of GUNK and mineral spirits (25%/75%) and spray it into the cooler. Be generous. Let it sit for a few minutes (5 or 10) and then flush it out with water until it runs clear. You can also remove the oil cooler from the airplane and used the same concoction to flush out the inter part of the cooler.
Using a good oil filter in the exit line from the engine (I use a 10 micron filter) keeps the oil cooler clean and thus more effective at cooling. In fact basically it keeps the whole system, (lines, cooler, and tank) clean. And the engine last a lot longer.
Jim "Pappy" Goolsby
In a message dated 7/11/2017 6:07:31 P.M. Eastern Daylight Time, flibob(at)att.net writes:
--> Yak-List message posted by: Robert Graves <flibob(at)att.net>
Sent from my ========================e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - NEW MATRONICS LIST WIKI -_-= - List Contribution Web Site sp;   ===================================================
Flibob
PostPosted: Tue Jul 11, 2017 6:56 pm    Post subject: Hi Oil temp Reply with quote
Thanks Walt I will double check that
GiddyUp,
Bob
On Jul 11, 2017, at 8:04 PM, Walter Lannon <wlannon(at)shaw.ca> wrote:
The first thing to consider with a CJ oil temp. question is are you reading oil IN or oil OUT?
Since it is your second CJ I'm sure you are familiar with the system but it's possible the switch is incorrectly wired or installed.
Walt
draftsjust417(at)gmail.co
PostPosted: Wed Jul 12, 2017 3:38 am    Post subject: Hi Oil temp Reply with quote
Btw Walt, very glad to hear about the rear gauge reading IN, I didn't know that, thanks-Justin Drafts, N280NC
On Tue, Jul 11, 2017 at 8:04 PM, Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
[quote]--> Yak-List message posted by: "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)>
Walt
Dawg
PostPosted: Wed Jul 12, 2017 7:23 am    Post subject: Hi Oil temp Reply with quote
so do you use In or Out for takeoff oil temp?
On Jul 12, 2017, at 20:35, Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
[quote]Btw Walt, very glad to hear about the rear gauge reading IN, I didn't know that, thanks-Justin Drafts, N280NC
Walt
Dawg
Flibob
PostPosted: Wed Jul 12, 2017 7:48 am    Post subject: Hi Oil temp Reply with quote
I always use in
On Jul 12, 2017, at 11:19 AM, Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
Walt
Ernie
PostPosted: Wed Jul 12, 2017 7:52 am    Post subject: Hi Oil temp Reply with quote
Generall Speaking they're relative. From a trend monitoring standpoint, OUT will give you a more direct indication engine performance.
On Wed, Jul 12, 2017 at 11:32 AM Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
[quote][quote]--> Yak-List message posted by: "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)>
Walt
Ernie
PostPosted: Wed Jul 12, 2017 7:57 am    Post subject: Hi Oil temp Reply with quote
IMHO, IN doesn't really say much by itself, but the spread between IN and OUT can tell you a lot. One who is so inclined to monitor and log that spread can gain a lot of insight when a observing a deviation from the mean spread between the 2 temps.
On Wed, Jul 12, 2017 at 11:51 AM Robert Graves <flibob(at)att.net (flibob(at)att.net)> wrote:
[quote]I always use in
Walt
jblake207(at)comcast.net
PostPosted: Wed Jul 12, 2017 8:21 am    Post subject: Hi Oil temp Reply with quote
Yeah, what he said... see attached.
To: yak-list(at)matronics.com
Sent: Wednesday, July 12, 2017 10:54:29 AM
Subject: Re: Hi Oil temp
[quote] I always use in
[quote] Btw Walt, very glad to hear about the rear gauge reading IN, I didn't know that, thanks- Justin Drafts, N280NC
Walt
 Filesize:  3.95 KB
 Viewed:  11972 Time(s)
Dawg
PostPosted: Wed Jul 12, 2017 12:41 pm    Post subject: Hi Oil temp Reply with quote
new to the CJ world. In from/to where, Out/from where to where?Where is the chip detector located? Pix?[quote]On Jul 12, 2017, at 10:18, JON <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:
From: "Ernest Martinez" <erniel29(at)gmail.com (erniel29(at)gmail.com)>To: yak-list(at)matronics.com (yak-list(at)matronics.com)Sent: Wednesday, July 12, 2017 10:54:29 AMSubject: Re: Hi Oil temp
On Tue, Jul 11, 2017 at 8:04 PM, Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote: [quote]--> Yak-List message posted by: "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)>The first thing to consider with a CJ oil temp. question is are you reading oil IN or oil OUT?Since it is your second CJ I'm sure you are familiar with the system but it's possible the switch is incorrectly wired or installed.Check switch in flight and/or compare with your GIB. Rear gauge is Oil IN.Walt-
Dawg
Ernie
PostPosted: Wed Jul 12, 2017 12:50 pm    Post subject: Hi Oil temp Reply with quote
You got a CJ??? Good man.
IN to engine from Oil Cooler
OUT from engine to Oil cooler.
IN is cooler than OUT.
On Wed, Jul 12, 2017 at 4:37 PM, William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
[quote]new to the CJ world. In from/to where, Out/from where to where?Where is the chip detector located? Pix?
Walt
Ernie
PostPosted: Wed Jul 12, 2017 12:51 pm    Post subject: Hi Oil temp Reply with quote
No Chip detector from factory.
On Wed, Jul 12, 2017 at 4:47 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
[quote]You got a CJ??? Good man.
Walt
Clouddog
PostPosted: Wed Jul 12, 2017 1:00 pm    Post subject: Hi Oil temp Reply with quote
Where you located with your CJ??
On Jul 12, 2017 15:44, "William Geipel" <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:[quote]new to the CJ world. In from/to where, Out/from where to where?Where is the chip detector located? Pix?
Walt
pfstelwagon(at)earthlink.
PostPosted: Wed Jul 12, 2017 1:26 pm    Post subject: Hi Oil temp Reply with quote
Actually, IN is from the tank into the engine OUT is from the engine to the oil cooler. The cooled oil goes back to the Oil tank. Remember Oil is the coolant as well as the lubricant.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Ernest Martinez
Sent: Wednesday, July 12, 2017 1:47 PM
To: yak-list <yak-list(at)matronics.com>
On Wed, Jul 12, 2017 at 4:37 PM, William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:[quote]
I always use in
On Tue, Jul 11, 2017 at 8:04 PM, Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:[quote]
Walt
Ernie
PostPosted: Wed Jul 12, 2017 1:34 pm    Post subject: Hi Oil temp Reply with quote
Ok, I left the tank out of the equation. Bottom line, IN is cooler than OUT
Dawg
PostPosted: Wed Jul 12, 2017 4:02 pm    Post subject: Hi Oil temp Reply with quote
Gone to the dark side…[quote]On Jul 12, 2017, at 14:48, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
On Wed, Jul 12, 2017 at 4:47 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:[quote]You got a CJ??? Good man.
On Wed, Jul 12, 2017 at 4:37 PM, William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:[quote]new to the CJ world. In from/to where, Out/from where to where?Where is the chip detector located? Pix?[quote]On Jul 12, 2017, at 10:18, JON <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:
Dawg
Dawg
PostPosted: Wed Jul 12, 2017 4:04 pm    Post subject: Hi Oil temp Reply with quote
Westcliffe, Colorado[quote]On Jul 12, 2017, at 14:57, Greg Wrobel <clouddog22(at)gmail.com (clouddog22(at)gmail.com)> wrote:
On Jul 12, 2017 15:44, "William Geipel" <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:[quote]new to the CJ world. In from/to where, Out/from where to where?Where is the chip detector located? Pix?[quote]On Jul 12, 2017, at 10:18, JON <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:
Dawg
Ernie
PostPosted: Wed Jul 12, 2017 4:51 pm    Post subject: Hi Oil temp Reply with quote
Jon,
I think you missed my point. The formula below is for standard deviation which is not what I was going for. To put it in terms that you might understand, if the difference between IN and OUT temps are normally lets just say 15 degrees C, then thats the mean, or average. If one day you realize that the spread between the two temps is greater or less than 15 degrees, then there is something to look at. If the OUT is the same but IN is higher then your oil cooler may not be working properly, or your oil level may be low. If the IN is the same but the OUT is higher then you may have something going on in the engine, etc etc etc.. There are many different scenarios that can play out here.
So MEAN means average, SPREAD means difference, MEAN SPREAD means the average difference of IN/OUT temps for your airplane.
Hope this helps.
Ernie
