BobbyPaulk(at)comcast.net Guest
Posted: Fri Sep 01, 2017 8:02 am Post subject: Alternator Belt |
I am running a Camit 40 amp alternator on my Jabiru 3300.
Does anyone know the Make and part number of the belt.
I don't need one yet but would like to replace it when the time comes.
It would be nice to find one at the local NAPA store.
Bobby ( age 79 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 290 Needle Jet
Status - Flying 282 hrs.
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
rwilhelm25(at)gmail.com Guest
Posted: Fri Sep 01, 2017 9:09 am Post subject: Alternator Belt |
You should be able to read the number on the top side of the belt. When I installed mine I checked the number and bout one from Auto Zone. Or maybe it was McMaster Carr.
I carry it in the plane.
Ray W
Sent from Mail for Windows 10
From: BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)
Sent: Friday, September 1, 2017 9:53 AM
To: Server, JabiruEngine-List Digest (jabiruengine-list(at)matronics.com)
Subject: Alternator Belt
Bobby ( age 79 )
Zodiac 601 XL "B"
matronics(at)rtist.nl Guest
Posted: Fri Sep 01, 2017 12:31 pm Post subject: Alternator Belt |
Check the fitting instructions that came with the alternator. It lists the belt partnumber
On 9/1/2017 5:57 PM, BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net) wrote:
| Quote: | I am running a Camit 40 amp alternator on my Jabiru 3300.
Bobby ( age 79 )
Zodiac 601 XL "B"
Posted: Sat Sep 02, 2017 2:46 pm Post subject: Alternator Belt |
Thanks to Ray and Rob for their help to find the correct Alternator belt for the Camit Alternator.
I have a number 3PK635 but I am not sure it is the correct length for the alternator mounted on the left hand ( pilot ) side.
More research needed. I did not get a parts list with my alternator.
I was also not aware they made one to be mounted on the right side.
Bobby
Jacksonville FL
Posted: Sat Sep 02, 2017 10:47 pm Post subject: Alternator Belt |
Hi Bobby,
The number at the end is the lenght in mm. So your 3PK635 is 635mm long. If you need a longer one, get a 3PK640. A shorter one? 3PK630. All of these are available for less than $10 online. '3PK' describes the width and type.
I didn't know there was a left-hand CAMit mount option, if so yours may be a one-off (or you have a pusher and it's a RH). Check if the current belt has any identifiers on it that may be a similar length indication.
Rob
On 9/3/2017 12:44 AM, BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net) wrote:
| Quote: | Thanks to Ray and Rob for their help to find the correct Alternator belt for the Camit Alternator.
Bobby
Jacksonville FL
