Removing cylinder head flashing
digidocs
PostPosted: Fri Jun 23, 2017 8:43 am    Post subject: Removing cylinder head flashing Reply with quote
Hi list,
What are your favorite techniques/tools for removing the cylinder head flashing (near the top spark plug)?
So far I've discovered Tim's approach using an extension drill like an end mill and also a suggestion to try modifying a hacksaw rod blade into long rotary burr.
Thanks for your input,
David
Tim Olson
PostPosted: Fri Jun 23, 2017 8:53 am    Post subject: Removing cylinder head flashing Reply with quote
I found a small thin file at our local farm store that fits nicely if the gap isn't completely closed.
I song have the info but it was maybe 6-8" long and maybe at most 1/2" wide and about 1/16" thick or so. That worked well.
Tim
On Jun 23, 2017, at 11:38 AM, David Carr <junk(at)dcarr.org> wrote:
Hi list,
David
Kellym
PostPosted: Fri Jun 23, 2017 12:14 pm    Post subject: Removing cylinder head flashing Reply with quote
I had good luck with one of my 3/32 (#40) drill bits, 6" long. Just made
multiple passes and then worked it back and forth somewhat. I can't say
I have seen significant difference, but with OAT around 100 for 9 am
takeoff, and 80 at 6500 and 70 at 9500..I'll have to wait for some more
normal temps to compare.
Tim, did you notice much benefit from the RTV between the cylinders,
where you closed the gap?
Tim
> Hi list,
> David
Kelly McMullen
KCHD
Tim Olson
PostPosted: Fri Jun 23, 2017 12:29 pm    Post subject: Removing cylinder head flashing Reply with quote
I didn't really have a good way to tell, sorry. The problem is, when I
attacked the
CHT issue, I did everything at once, so I can't say that one thing was
far better than any other. The Cylinder flashing issue was a definite
problem though...you could just see it. Funny that my IO-390 cylinders
from Lycoming didn't need any work at all. Maybe these days they
do a better job, or maybe they do a better job than ECI did.
My real remaining thing I'd some day like to improve is Oil temps.
Interestingly, it used to be my CHT's that were the issue, not oil temps.
Then after fixing the CHT's, now if there is anything that limits me
from climbs on hot days it's oil temps. I set my alarm at 216F to come
on and get me to do something. I don't ever let it get over 225F
without great reason. I may have seen 235F one or two times in
1250 hours. By keeping speeds of 125kts in climb I can almost
do whatever I want, but I would prefer to be able to have my oil
temps stay under 210F even in 115kt climbs...and always be
in the 190's when straight and level.
I may just have to get into a small cowl mod to add an extra exit
scoop or something under that oil cooler. It's not a highly pressing
issue, but would be nice to deal with for any flights out West in
the warm months, mainly.
Tim
made multiple passes and then worked it back and forth somewhat. I
can't say I have seen significant difference, but with OAT around 100
for 9 am takeoff, and 80 at 6500 and 70 at 9500..I'll have to wait for
some more normal temps to compare.
Kellym
PostPosted: Fri Jun 23, 2017 12:42 pm    Post subject: Removing cylinder head flashing Reply with quote
Very interesting. I replaced my louvers in front of the exhaust pipes
with the Anti-Splat cowl flaps. This was first supported by putting 1/2"
deflector in front of the louvers, which made a noticeable improvement.
with the cowl flaps, temps are a bit lower, maybe as good as with the
deflector in front of louvers(which would have been a lot cheaper and
easier to stick with). However, where my oil temps had been fine, now
mine are like yours. I did the flashing removal, but haven't tried the
RTV yet. I just need to get my cockpit flow back to where it was flying
the Mooney....cowl flaps open for takeoff and climb. Level off, and then
close cowl flaps. Open them up as come into pattern to keep CHTs from
climbing again. I may eventually decide to install one of the louvers I
removed, right under the oil cooler.
Your IO-390 cylinders should be perfect...they should be perfect. I
don't know if you have priced them, but they are almost double the price
of regular 360 angle valve cylinders.
attacked the
Tim
Kelly McMullen
KCHD
Bob Turner
PostPosted: Fri Jun 23, 2017 1:00 pm    Post subject: Re: Removing cylinder head flashing Reply with quote
These results shouldn't be too surprising. By improving air flow over the cylinders, you decreased the top cowl pressure a bit. So now there's less air flow to the oil cooler.
Bob Turner
RV-10 QB
Tim Olson
PostPosted: Fri Jun 23, 2017 1:11 pm    Post subject: Removing cylinder head flashing Reply with quote
Smile Yeah, the 390's aren't cheap. At least it's good. It gave me the
confidence that
I may buy my next RV-10 engine as the Van's brand new engine.
My CHT's have been great for a long time. I don't ever hit 400 on climb
or anything. If it weren't for the oil temp I wouldn't have a complaint.
So you're saying the deflector in front of the louvre lowered the
CHT's (I mean, is the CHT temp the thing you were chasing, or oil temp),
but then adding the cowl flap didn't really make a big difference over
the deflector, right? So either solution helped for CHT's, but
then now with EITHER of them you began to have higher oil temps?
I just want to understand what cause and effect you had. I don't
want to go cutting cowl holes unless I have a good idea that it'll work.
Maybe I'll try just adding an aft curled down lip to the cowl exit
and see how that goes. Something that I can tape on.
I do have the oil cooler throttle valve to keep the oil temps higher
in the winter. Sadly when you live here, but travel all over, you need
something to help with both high and low oil temps. Smile
As Bob just noted, maybe the good flow thru the cylinders is actually
hurting our oil cooler capabilities. Or maybe it's the angle that the
oil cooler is at. If you see how they did the RV14 cooler, it lays
horizontal. My RV-14 has zero CHT or Oil temp issues. In fact, the
Cylinders run super cool. So they did something right on that plane
that would be nice to do on the -10.
Tim
1/2" deflector in front of the louvers, which made a noticeable
improvement.
flying the Mooney....cowl flaps open for takeoff and climb. Level off,
and then close cowl flaps. Open them up as come into pattern to keep
CHTs from climbing again. I may eventually decide to install one of
the louvers I removed, right under the oil cooler.
price of regular 360 angle valve cylinders.
> I attacked the
> temps.
> Tim
Deems Davis
PostPosted: Fri Jun 23, 2017 1:40 pm    Post subject: Removing cylinder head flashing Reply with quote
Kelly,
I messed with cht, and oil temps for far too long, I can say that louvers had no noticeable effect. Adding the bigger cooler also had negligible effect. I final solution that solved the issue, was to fashion a ram air intake that combined with the close-out plate on the bottom of the cowl that fits in front of the nose gear. Attached a 3" scat tube and ran that into a fiberglass right angle reducer that coupled with the 3" scat tube and affixed to the top of the oil cooler. Closed off the old oil cooler air intake behind #6. The difference was dramatic, IMO for anything other than cold environs the 10 oil cooler mounting and plumbing is inadequate. For us in the desert the oil cooler demands it's own dedicated air supply. And as you would surmise #6 cyl was now inline with all others, and all others showed a drop in CHTs.
On Fri, Jun 23, 2017 at 1:39 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Very interesting. I replaced my louvers in front of the exhaust pipes with the Anti-Splat cowl flaps. This was first supported by putting 1/2" deflector in front of the louvers, which made a noticeable improvement.
with the cowl flaps, temps are a bit lower, maybe as good as with the deflector in front of louvers(which would have been a lot cheaper and easier to stick with). However, where my oil temps had been fine, now mine are like yours. I did the flashing removal, but haven't tried the RTV yet. I just need to get my cockpit flow back to where it was flying the Mooney....cowl flaps open for takeoff and climb. Level off, and then close cowl flaps. Open them up as come into pattern to keep  CHTs from climbing again. I may eventually decide to install one of the louvers I removed, right under the oil cooler.
Your IO-390 cylinders should be perfect...they should be perfect. I don't know if you have priced them, but they are almost double the price of regular 360 angle valve cylinders.
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
I didn't really have a good way to tell, sorry.  The problem is, when I attacked the
Tim
I had good luck with one of my 3/32 (#40) drill bits, 6" long. Just made multiple passes and then worked it back and forth somewhat. I can't say I have seen significant difference, but with OAT around 100 for 9 am takeoff, and 80 at 6500 and 70 at 9500..I'll have to wait for some more normal temps to compare.
Tim, did you notice much benefit from the RTV between the cylinders, where you closed the gap?
WIKI -
bhoppe2
PostPosted: Fri Jun 23, 2017 2:38 pm    Post subject: Removing cylinder head flashing Reply with quote
Kelly,
I have looked at the Anti-Splat cowl flap. What caught my interest is your comment about "putting 1/2" deflector in front of the louvers". Please describe this deflector in a little more detail. If you have a photo, that would be very helpful.
My main concern has been high CHTs, especially on cylinder #6 on initial climb out. It will usually go above 400F especially in the summer in TN, then drops under 400. At cruise, all CHTs typically are 350-380F or lower depending how far LOP, with #6 still being the hottest. I normally have a 30F CHT range between the hottest land coolest cylinders. One theory is that the air for the oil cooler is diverting cooling air from #6.
I recently reinstalled the air deflector in front of cyl#2 and put RTV between the cylinders. That helped the temperature spread only a little, but every little bit helps.
It helped to balance my injectors, including on climb out. Now, all EGTs peak within 0.1GPH. Typically, no problems with oil temp. I have an adjustable damper on the oil cooler, but it only lowers #6 CHT 1 or 2 degrees when I partially close it to raise oil temp by 20 degrees.
Bruce Hoppe
RV-10 N720JH
Bruce Hoppe
> Tim
Bruce Hoppe
Kelly McMullen
PostPosted: Fri Jun 23, 2017 3:48 pm    Post subject: Removing cylinder head flashing Reply with quote
Good to hear from you Deems. That certainly is worthy of some thought. Getting more pressure over #6 would definitely help. My concern would be getting enough ram air pressure in front of nose gear to adequately cool the oil.
Tim, my original issue was high CHTs. Adding the lip in front of the louvers helped, and I don't recall any downside to oil temp.
I only saw higher oil temp after I swapped from louvers to cowl flaps.
However, remember, I am flying in triple digit temps, and comparing to a month ago when temps were more in the 80s. I had high CHT on climb all winter, as well as during phase 1 last summer. The main method for CHT control was to get power under 65% and airspeed above 120. In cruise everything was fine as long as I didn't go above 70% power. Originally, if I didn't pay attention CHT would easily go above 430. Now, 1, 5 and 6 will go to 410 in climb if I try to go above 500 fpm for very long.
-sent from the I-droid implanted in my forearm
On Fri, Jun 23, 2017 at 2:39 PM, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
Kelly,
Tim
WIKI -
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Kellym
PostPosted: Fri Jun 23, 2017 6:50 pm    Post subject: Removing cylinder head flashing Reply with quote
Bruce, if you will recall the Z channel that is used for stringers in
the tail cone. I used that, cut one curve off, to have thin, 1/2 right
angles. I cut to width of the louvers. then used Gorilla brand duct tape
to tape them in place, just as a temporary trial. I noticed about 20-30
degree drop in CHT.
On 6/23/2017 3:37 PM, Bruce Hoppe wrote:
Kelly,
Bruce Hoppe
RV-10 N720JH
Bruce Hoppe
>> Tim
Kelly McMullen
KCHD
Greg McFarlane
PostPosted: Sat Jun 24, 2017 4:03 am    Post subject: Re: Removing cylinder head flashing Reply with quote
I was concerned about high CHT & Oil temps in local RV10s here so I was very lucky to get some details from Deems about his mod when I was fitting my engine, I took his idea a bit further and I'm pleased to say that it has worked out extremely well. I can keep CHT under 350 and oil at 180. (we have mid 30 to 40*C conditions at times) As the pics show I added an intake for the oil cooler to the bottom cowl, a manifold then takes the air to the left of the front wheel slot (1/2" below the fab) and then via a 4" scat to the vertically mounted standard oil filter. Air is regulated by a push/pull butterfly valve at the oil cooler (Not visible) and exhausts out of the oil cooler couple inches from the side of the cowl. No air is bled off the top of the engine so all is available for CHT cooling. CHTs are even on all cylinders. I didn't fit the flimsy louvres or cowl flaps but installed letterbox vents on both sides. I did fit a "cowl flap" on the side of the cowl next to the oil cooler because I didn't know if the air flow through the cooler would be enough, but this hasn't been needed so I've now permently fixed it shut. One downside to the mod is that the scat hose must be removed before taking the bottom cowl off, not a big deal, the scat is a push fit into the manifold and is secured by hand with a -3 bolt into a nut plate. Anyway, not really about CHT flashing but related to the cooling discussion. Cheers from Western Australia
 Filesize:  1.64 MB
 Viewed:  15686 Time(s)
 Filesize:  1.35 MB
digidocs
PostPosted: Sat Jun 24, 2017 9:00 pm    Post subject: Removing cylinder head flashing Reply with quote
Thanks for all of the advice on the flashing!  This list is a great resource.
David
On Fri, Jun 23, 2017 at 11:53 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
Tim
> On Jun 23, 2017, at 11:38 AM, David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote:
> Hi list,
> David
WIKI -
