Posted: Wed Jun 21, 2017 8:34 am Post subject: Fuselink vs. blade fuse (CORRECTION) |
| Quote: | | I see no reason why the circuit breaker needs to be mounted on the down steam side of the master switch. Connect the circuit breaker directly to and close to the main power bus. Then no fuselink is needed. |
Not so much 'down stream' as 'adjacent to'
that switch.
[img]cid:7.1.0.9.0.20170621113254.061c4790(at)aeroelectric.com.1[/img]
Fuse blocks are generally mounted out of sight,
out of mind. The necessity for a single breaker
to be part of the mix calls for extending the
bus to the switch location . . . hence protection
more robust than BOTH fuses and breakers, i.e.
fusible link.
17.91 KB |
2277 Time(s) |
