BobbyPaulk(at)comcast.net Guest
Posted: Wed Jun 07, 2017 5:42 am Post subject: Engine Mounts |
Joe,
I installed my engine in 2006 and did not have access to a lot of info now available.
The washers you mention ( I assume ) go against the rubber doughnuts on the engine mount. They are to be used in compression so two will be on the back side and two will be on the front. There is a photo somewhere showing how they are installed but I can not find it. They are not shown in some photos so I did not install them at first. I flew about 60 hours and found out that I had left them out. I bought new rubber mounts of higher durometer ( stiffer ) and installed the washers. This raised the engine just enough that I had to patch and re-drill the cowling attach screws. I did not have to do it but the spinner was about 1/2" off the vertical center and I did not like the looks of it. Don't take my word but check it out thoroughly before you fit the cowl.
Bobby ( age 79 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 290 Plus .002 Needle Jet
Status - Flying 275 hrs.
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Fri Jun 09, 2017 3:13 am Post subject: Engine Mounts |
Joe,
I am using the Sonex doughnuts and they do seem better than the original ones.
I have not noticed any additional vibration.
Bobby
