New Break-away Tail Wheel
KJ4CTZ
PostPosted: Sun Apr 16, 2017 5:52 am    Post subject: New Break-away Tail Wheel Reply with quote
Gentlemen,
I bought a new breakaway tail wheel from Kolb at Sun N Fun this year. Attempting to replace my original wheel, It appears like the original is JB Welded to the solid aluminum tail rod.
What is the recommended procedure for removing the original tail wheel assembly?
williamtsullivan(at)att.n
PostPosted: Sun Apr 16, 2017 6:20 am    Post subject: New Break-away Tail Wheel Reply with quote
If it's aluminum, heat from a propane torch will break the bond. A wet rag wrapped around the aluminum will keep the heat from traveling up to the tail skeg. Maybe try to twist a bit while heating, so you know when it lets go. It shouldn't take much heat. Or, as suggested earlier this week, cut it off to shorten it a bit.
Bill Sullivan
<Kj4ctz(at)gmail.com>
Gentlemen,
gdhelton(at)gmail.com
PostPosted: Sun Apr 16, 2017 7:11 am    Post subject: New Break-away Tail Wheel Reply with quote
A propane torch should do the trick. Just heat it lightly all the way around. It will break loose.Keep wet cloth with around to keep to much heat from transferring to the tail post.
Have a great day!
On Apr 16, 2017, at 9:52 AM, KJ4CTZ <Kj4ctz(at)gmail.com> wrote:
Gentlemen,
http://forums.matronics.com/viewtopic.php?p=468520#468520
KJ4CTZ
PostPosted: Sun Apr 16, 2017 7:57 am    Post subject: Re: New Break-away Tail Wheel Reply with quote
Thanks guys,
I will try mild heat first. If no success I will cut off and put new assembly on.
Should it also be JB Welded back on? I assume so but open to suggestions.
This forum is great and I appreciate everyone's comments.
PostPosted: Sun Apr 16, 2017 8:13 am    Post subject: New Break-away Tail Wheel Reply with quote
I re-mounted my tail wheel on a very early Firestar because it was crooked. I had the fiberglass rod. I used a 1/4" bolt through it. I was a truck equipment mechanic, so I have a tendency to overdo things a bit.
Bill Sullivan
On Sun, 4/16/17, KJ4CTZ <Kj4ctz(at)gmail.com> wrote:
Subject: Re: New Break-away Tail Wheel
Date: Sunday, April 16, 2017, 11:57 AM
Thanks guys,
PostPosted: Sun Apr 16, 2017 5:30 pm    Post subject: New Break-away Tail Wheel Reply with quote
Heat will definitely break JB weld loose. I actually just replaced the tailwheel on my Firestar 1 with the new Kolb breakaway unit. I had drill out the fiberglass tail strut which was a real pain, but JB had failed at tailwheel assembly. So I installed a new T7075 tail strut. I just locked it into lower vertical stabilizer with a single bolt at both ends. Here's a couple of pictures.
I did coat the inside of both end with a liberal amount of white silicon to seal out moisture.
George H.
Firestar 1, #FS100
14GDH
Mesick, MI
Have a great day!
On Apr 16, 2017, at 11:57 AM, KJ4CTZ <Kj4ctz(at)gmail.com> wrote:
Thanks guys,
http://forums.matronics.com/viewtopic.php?p=468526#468526
 Filesize:  107.74 KB
 Viewed:  6904 Time(s)
 Filesize:  74.15 KB
 Filesize:  61.56 KB
KJ4CTZ
PostPosted: Sat Apr 22, 2017 10:49 am    Post subject: Re: New Break-away Tail Wheel Reply with quote
Thanks guys,
I applied a little heat with a propane torch and used a very large crecent wrench to twist off the old tailwheel. Worked like a charm.
Thanks for the help,
