Is a battery contactor really needed?
rv8ch
PostPosted: Wed Apr 12, 2017 12:35 pm    Post subject: Is a battery contactor really needed? Reply with quote
There seem to be a lot of advantages to not disconnecting the alternator from the battery, so I'm wondering if the battery contactor is really necessary?
The things I can see as advantages are that it provides an extra layer of protection from accidental starter engagement, and provides a big switch that can be used to disconnect the battery from everything.
I'm curious if there are other advantages that I'm not seeing.
Thanks!
Mickey Coggins
http://www.rv8.ch/
PostPosted: Wed Apr 12, 2017 3:08 pm    Post subject: Re: Is a battery contactor really needed? Reply with quote
In case of an immanent forced landing or smoke in the cockpit, it is advisable to shut off electrical power as close to the source as possible.
Joe Gores
PostPosted: Thu Apr 13, 2017 12:43 pm    Post subject: Is a battery contactor really needed? Reply with quote
At 03:35 PM 4/12/2017, you wrote:
--> AeroElectric-List message posted by: "rv8ch" <mick-matronics(at)rv8.ch>
There is a legacy train of thought that goes
back nearly 100 years . . . when on short final
to the rocks, it's a good idea to suppress
risk to the smallest values.
Hence, the POH for most if not all TC aircraft
calls for shutting off the fuel and killing
the electrical system. Getting the electrical
system stone-cold calls for independent, positive
control over power sources like alternators, generators
and . . . you guessed it . . . batteries.
Of course, the contactor is also a hedge against
a stuck starter contactor . . .
Don't know what 'advantages' might be secured
with permanent pathways between alternators
and batteries.
rv8ch
PostPosted: Thu Apr 13, 2017 8:26 pm    Post subject: Re: Is a battery contactor really needed? Reply with quote
and batteries.
Thanks for the feedback gents, looks like the off field landing scenario slipped my mind when thinking about this. The "advantages" I was thinking of were one less component, and the possible avoidance of a load dump if the alternator is pumping hard and the battery is disconnected. Avoiding issues with a load dump are pretty easy by following the recommended designs in the 'connection. Thanks for the tips!
Mickey Coggins
http://www.rv8.ch/
trigo(at)mail.telepac.pt
PostPosted: Fri Apr 14, 2017 5:51 am    Post subject: Is a battery contactor really needed? Reply with quote
Hello Mickey
I suppose everything is ok with you and your family, and you are flying your RV-8 in beautiful Switzerland
Cheers
Carlos
Enviado do meu iPhone
No dia 14/04/2017, às 05:26, rv8ch <mick-matronics(at)rv8.ch> escreveu:
> and batteries.
Mickey Coggins
http://www.rv8.ch/
http://forums.matronics.com/viewtopic.php?p=468379#468379
eschlanser
PostPosted: Wed Apr 26, 2017 6:39 am    Post subject: Re: Is a battery contactor really needed? Reply with quote
It's been a couple of years since I designed my plane's electrical system with no battery contactor.
What brand or style battery contactor is preferred/acceptable for a OBAM airplane with a Z - (x) wiring system? I installed the barrel style starter contactor but replaced it with the flat style when Bob recommended that change. Now I'm wondering if there's a new style of battery contactor that has superseded the barrel style.
One advantage to eliminating the battery contactor is keeping the voltage available for starting that would be lost to the battery contactor.
Eric - W10 with Z-8 inspired elec system.[/u]
