Posted: Sat Apr 08, 2017 6:56 pm Post subject: Blue Bird Flight |
Late this evening I pushed the MKIII out of the hanger. Not an easy job loaded down with 25 gal, 150 lbs, of 91 oct mogas. This was fuel to get me halfway to Lakeland.
The MKIII performed well. Great flying weather, no wind and cool.
I checked out stall speed, idle power, with this load:
35-36 mph clean.
32 mph 20 deg flaps.
30 mph 40 deg flaps.
Shot a dozen landings in all configurations without blowing any of them. I can't take credit for that. I think the VGs are working.
Not sure if I have lost any cruise speed or not. If I have, it is very close, if at all.
_________________ John Hauck
Titus, Alabama |
gdhelton(at)gmail.com Guest
Posted: Sat Apr 08, 2017 7:19 pm Post subject: Blue Bird Flight |
John, it's good to hear you're up there having some fun. I finished the new breakaway tailwheel project today. Now I just need some warm weather up here in northern Michigan so I can finish painting the left wing on the old Firestar MK1, so I can try it out.
[img]cid:F186078C-007D-4456-AFCB-78E23C394470[/img]
George H.
Firestar MK1, #FS100
14GDH
gdhelton(at)gmail.com (gdhelton(at)gmail.com)
Mesick, Michigan
Have a great day!
On Apr 8, 2017, at 10:56 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
| Quote: | Blue Bird Flight
35-36 mph clean.
61.56 KB |
3761 Time(s) |
lcottrell
Posted: Sat Apr 08, 2017 7:20 pm Post subject: Blue Bird Flight |
Glad that you could get out John. It was a good reward for you, if you
know what I mean.
I have always found the idea that having the "little bitty thingy ma
bobs" on your wing that are designed to reattach the air flow to said
wing, being maligned because "they might" slow your plane down a bit,
to be a bit of a head scratcher. ( I might still be suffering from
inaccurate writing here.) I had always thought that air swirling from
being unattached was the culprit, not the solution. Heck, you could be
going faster.
Just look at it this way. What is the first thing you do when you get
in rough weather? You slow down! It could be an improvement built in.
Still a bit cranky,
Larry
On Sat, Apr 8, 2017 at 8:56 PM, John Hauck <jhauck(at)elmore.rr.com> wrote:
| Quote: | Late this evening I pushed the MKIII out of the hanger. Not an easy job
| Quote: | Not sure if I have lost any cruise speed or not. If I have, it is very
close, if at all.
If you forward this email, or any part of it, please remove my email
address before sending.
Posted: Sat Apr 08, 2017 9:05 pm Post subject: Blue Bird Flight |
You're right, John. Original is just to much typing every time. I'll just use Firestar 1 in the future. I did build a Twinstar Mk II which was the second variant of original Twinstar. (open to enclosed cockpit)Which lead to the original MkIII.
[img]cid:12C315B3-5FAC-4293-8ED7-48B1185CB2C5[/img]
George H.
Firestar 1,(original) #FS100
14GDH
Mesick, Michigan
Have a great day!
On Apr 9, 2017, at 12:08 AM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
| Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]-->Blue Bird Flight <![endif]--> <![endif]-->
I think George H has invented a new model Firestar, the MKI.
If memory serves me correctly these are the Firestar models. Ya'll correct me if I am wrong.
-Firestar
-Firestar KXP
-Firestar II
Don't think there was a MKI, but I know what you are getting at. Folks, not Homer Kolb, decided to call the first FS model the "original" FS, and the "original" MKIII.
BTW: You could cut that tail wheel strut in half and still have more strut than you will ever need. Shortening the strut reduces torsional twist, bouncing, bending, and wiggling. Makes tail wheel steering a little tighter. I use a 6" (exposed length) .120" wall heat treated 4130 strut. Works good on Miss P'fer.
From: owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com) [mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of George Helton
Sent: Saturday, April 08, 2017 10:19 PM
Subject: Re: Blue Bird Flight
<image001.jpg>
George H.
14GDH
Mesick, Michigan
Have a great day!
35-36 mph clean.
80.45 KB |
3756 Time(s) |
Posted: Sun Apr 09, 2017 12:47 pm Post subject: Blue Bird Flight |
John, I meant to thank you for tailwheel strut info. Makes sense to me. I'll give shortening it up a bit a try. I just left the length the same as the original fiberglass strut.
George H.
Firestar 1, #FS100
14GDH
Mesick, Michigan
Have a great day!
-Firestar
-Firestar KXP
-Firestar II
<image001.jpg>
George H.
14GDH
Mesick, Michigan
Have a great day!
35-36 mph clean.
Posted: Sun Apr 09, 2017 2:27 pm Post subject: Blue Bird Flight |
George H/Kolbers:
The two photos will give you an idea what mine looks like.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of George Helton
Sent: Sunday, April 09, 2017 3:45 PM
George H.
Firestar 1, #FS100
14GDH
Mesick, Michigan
Have a great day!
-Firestar
-Firestar KXP
-Firestar II
<image001.jpg>
George H.
14GDH
Mesick, Michigan
Have a great day!
35-36 mph clean.
309.99 KB |
3744 Time(s) |
303 KB |
3744 Time(s) |
Titus, Alabama |
