MGL CHT probe
jpoint(at)wi.rr.com
PostPosted: Tue Apr 04, 2017 7:45 pm    Post subject: MGL CHT probe Reply with quote
I recently purchased the MGL 18mm spark plug CHT probes from Aircraft Spruce.  The photo on both their website and MGL's shows a copper ring soldered to a K-type thermocouple wire, a pretty standard setup.  What they sent me is pictured below.  Since the bare wire ends connect directly to the RDAC brain box, I deduced that the other end- a 1/4 PIDG fast-on, crimped to the thermocouple wires- must just attach to the copper ring.  The tab end of the copper ring is exactly 1/4 inch, so this makes sense.
This seems like a pretty cheeseball setup.  From what I know of K-type thermocouples (mostly from reading the 'Connection) that wires must be silver soldered to the probe and to each other.  Or, am I mistaken and is this a reasonable setup?
I am also reaching out to MGL about this, but I thought I'd ping this group for your thoughts as well.
Jeff Point
Milwaukee
[img]cid:part1.6A37B435.25B20261(at)wi.rr.com[/img]
 Filesize:  188.34 KB
 Viewed:  2499 Time(s)
kjashton(at)vnet.net
PostPosted: Wed Apr 05, 2017 3:37 am    Post subject: MGL CHT probe Reply with quote
On Apr 4, 2017, at 11:42 PM, Jeff Point <jpoint(at)wi.rr.com (jpoint(at)wi.rr.com)> wrote:This seems like a pretty cheeseball setup. From what I know of K-type thermocouples (mostly from reading the 'Connection) that wires must be silver soldered to the probe and to each other. Or, am I mistaken and is this a reasonable setup?
What you have will probably work just fine but yes, the high dollar thermocouples usually silver-solder the wires to the copper ring and incorporate a support (pic), however they’re amazingly expensive.
Silver-soldering is a good skill to learn and does not take much more than a propane torch and the proper materials. Here are a couple I made as an experiment (2nd pic). They use copper sparkplug gaskets and a piece of stainless welding wire as the support. A “resist” is a material applied to the parts that you don’t want the solder to flow onto. Wite-out makes a pretty good resist. The tricky part is jigging the parts while you heat them. This place has all the supplies and there are many Youtube videos.
https://contenti.com
Time or money, take your choice. Smile
-Kent
[img]cid:3249BA92-0C21-4B0A-B18E-CC3BBDAA0951[/img][img]cid:63847E6A-409C-49BE-AFD0-E5BE3A5A5DCD[/img]
 Filesize:  74.18 KB
 Viewed:  2495 Time(s)
 Filesize:  72.2 KB
