vernon.franklin(at)gmail. Guest
Posted: Tue Mar 28, 2017 4:51 am Post subject: Spider Identification |
Could someone help me identify what this GAGE connection is? How should I terminate it?
Is this an overflow?
Thanks!
[img]cid:ii_15b14f6755030dab[/img]
Vernon Franklin
1.85 MB |
6153 Time(s) |
Dave Saylor
Posted: Tue Mar 28, 2017 6:08 am Post subject: Spider Identification |
If you have a fuel flow sensor like the red cube, etc., you can just cap it. It's used by some installations to display fuel pressure (often converted to fuel flow) in the cockpit.--Dave
On Tue, Mar 28, 2017 at 5:50 AM, Vernon Franklin <vernon.franklin(at)gmail.com (vernon.franklin(at)gmail.com)> wrote:
| Quote: | Could someone help me identify what this GAGE connection is? How should I terminate it?
Thanks!
Vernon Franklin
1.85 MB |
6150 Time(s) |
_________________ --Dave
KWVI |
Lenny Iszak
Posted: Tue Mar 28, 2017 6:16 am Post subject: Re: Spider Identification |
I plugged it. Here's a picture of my spider and a diagram from the Silverhawk manual.
| vernon.franklin(at)gmail. wrote: | Could someone help me identify what this GAGE connection is? How should I terminate it?
Thanks!
Vernon Franklin |
48.85 KB |
6138 Time(s) |
784.86 KB |
6138 Time(s) |
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
Don Orrick
Posted: Tue Mar 28, 2017 7:25 am Post subject: Spider Identification |
Yes, plug it or it will leak fuel. I thought it was a bleeder but it isn't and won't leak anytime fuel pressure is applied. Only I Kept finding fuel stains on the spyder and finally figured it out.
Bob Turner
Posted: Tue Mar 28, 2017 9:02 am Post subject: Re: Spider Identification |
You can find the fitting you need to cap it off at places like Aircraft Spruce.
_________________ Bob Turner
RV-10 QB |
Tim Olson
Posted: Tue Mar 28, 2017 9:13 am Post subject: Spider Identification |
I think I used a 1/8" NPT plug from something else...they're
available all over the place but something tells me we even
got some extras either with the kit or with something
that I bought for the engine or avionics.
Tim
On 03/28/2017 12:02 PM, Bob Turner wrote:
maca2790
Posted: Tue Mar 28, 2017 1:31 pm Post subject: Spider Identification |
Yes I had the same issue as mentioned. Fuel staining the crankcase because of a small leak from the fitting. There were some spare 1/8 NPT plugs in the Fire Wall forward kit and I used one of those to plug it.
Cheers John MacCallum
RV10 41016
VH-DUU
Tim
> Bob Turner
> RV-10 QB
> http://forums.matronics.com/viewtopic.php?p=467755#467755
