dfritz(at)bpgsim.com Guest
Posted: Fri Mar 24, 2017 8:35 pm Post subject: Interior Paint |
I am nearing the point when I will need to paint the interior of my
fuselage. Looking at the paint options, I find the Stewart Systems
water based paint to be attractive from a safety perspective. Has
anyone used their product, and if so what was your experience, both
positive and negative.
Dave Fritzsche
Posted: Fri Mar 24, 2017 9:51 pm Post subject: Interior Paint |
I've only used a few Stewart products ..... They're OK. However I went with Zolatone. It's water based also.
[img]cid:part1.FBAA27A5.FCC4DACA(at)cfl.rr.com[/img]
Linn
On 3/25/2017 12:34 AM, David J. Fritzsche wrote:
| Quote: | --> RV10-List message posted by: "David J. Fritzsche" <dfritz(at)bpgsim.com> (dfritz(at)bpgsim.com)
I am nearing the point when I will need to paint the interior of my fuselage. Looking at the paint options, I find the Stewart Systems water based paint to be attractive from a safety perspective. Has anyone used their product, and if so what was your experience, both positive and negative.
Dave Fritzsche
Checked by AVG - www.avg.com
03/24/17
77.78 KB |
3793 Time(s) |
rv10flyer(at)live.com Guest
Posted: Sat Mar 25, 2017 9:44 am Post subject: Interior Paint |
I painted my complete (exterior) plane in my garage using Stewart Systems. 5 years later still holding up very well. I am sure the interior is equally good.
Pros-
support is outstanding
Waterbased wise a good product
Cons
Mostly my skill I gather but needed to be applied lighter than I would have liked due to running when applied per instructions and recoating when instructed, time between coats needed to be extended to resolve issues. Still more coats (aka time) needed than spray painted oil based paints.
If I did the paint again, I would more than likely use their product again, probably use a different spray gun too.
