Kolb-List Digest: 0 Msgs - 03/21/17
tc1917(at)bellsouth.net
PostPosted: Wed Mar 22, 2017 11:34 am    Post subject: Kolb-List Digest: 0 Msgs - 03/21/17 Reply with quote
Got a guy in alabama near auburn looking for ultralight type folding aircraft to putt putt around. Need work, ok. Reply email
On Mar 22, 2017, at 2:03 AM, Kolb-List Digest Server <kolb-list(at)matronics.com> wrote:
Today's complete Kolb-List Digest can also be found in either of the
of the Kolb-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-03-21&Archive=Kolb
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-03-21&Archive=Kolb
Kolb-List Digest Archive
Total Messages Posted Tue 03/21/17: 0
Today's Message Index:
gdhelton(at)gmail.com
PostPosted: Wed Mar 22, 2017 4:22 pm    Post subject: Kolb-List Digest: 0 Msgs - 03/21/17 Reply with quote
There were some here talking about new tailwheels for all models of Kolb aircraft. I ordered and received my new breakaway tailwheel assembly from Kolb and thought I would share a few pictures of it prior to installation on my Firestar MK1.
Have a great day!
George Helton (Maddog)
14GDH
> HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2017-03-21&Archive=Kolb
> Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2017-03-21&Archive=Kolb
 Filesize:  36.27 KB
 Viewed:  8536 Time(s)
 Filesize:  34.71 KB
 Filesize:  33.3 KB
PostPosted: Wed Mar 22, 2017 4:39 pm    Post subject: Kolb-List Digest: 0 Msgs - 03/21/17 Reply with quote
Is the tail wheel being fabricated by Kolb Aircraft?
PostPosted: Wed Mar 22, 2017 4:52 pm    Post subject: Kolb-List Digest: 0 Msgs - 03/21/17 Reply with quote
Yes it is John. It's kinda pricey at $130.00 plus I had to order the aluminum tail rod (at) $33.00. But, my Firestar still has the old fiberglass rod. I not willing to trust it. I had a fail of one on my Twinstar MK2 and that was a lesson learned.
Have a great day!
[quote] On Mar 22, 2017, at 8:34 PM, John Hauck <jhauck(at)elmore.rr.com> wrote:
byoungplumbing(at)gmail.c
PostPosted: Wed Mar 22, 2017 4:58 pm    Post subject: Kolb-List Digest: 0 Msgs - 03/21/17 Reply with quote
What diameter is the wheel?
Boyd y
On Mar 22, 2017 6:29 PM, "George Helton" <gdhelton(at)gmail.com (gdhelton(at)gmail.com)> wrote:
Have a great day!
14GDH
> On Mar 22, 2017, at 3:33 PM, Ted Cowan <tc1917(at)bellsouth.net (tc1917(at)bellsouth.net)> wrote:
> --> Kolb-List message posted by: Ted Cowan <tc1917(at)bellsouth.net (tc1917(at)bellsouth.net)>
> Sent from my iPhone
>> On Mar 22, 2017, at 2:03 AM, Kolb-List Digest Server <kolb-list(at)matronics.com (kolb-list(at)matronics.com)> wrote:
>> HTML Version:
>> Text Version:
PostPosted: Wed Mar 22, 2017 5:05 pm    Post subject: Kolb-List Digest: 0 Msgs - 03/21/17 Reply with quote
I found the fiberglass tail wheel strut was extremely flexible, overly so.
The aluminum rod will do a much better job.
PostPosted: Wed Mar 22, 2017 5:20 pm    Post subject: Kolb-List Digest: 0 Msgs - 03/21/17 Reply with quote
The new wheel is about the same as the old cookie cutter wheel at basically 6". But the new wheel is 1 1/8 inches wide. It comes with sealed bearing and new cable tension springs.
Brian as at Kolb is interested in some feed back. It looks really great. I'll let you know what I think down the road.
George H.
14GDH
Have a great day!
On Mar 22, 2017, at 8:57 PM, B Young <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)> wrote:
Boyd y
Have a great day!
14GDH
> Sent from my iPhone
>> HTML Version:
>> [url=http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-03-21&Archive=Kolb]http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-03-21&Archive=Kolb[/url]
>> Text Version:
>> [url=http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-03-21&Archive=Kolb]http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-03-21&Archive=Kolb[/url]
lcottrell
PostPosted: Wed Mar 22, 2017 6:15 pm    Post subject: Kolb-List Digest: 0 Msgs - 03/21/17 Reply with quote
It appears to be similar to the breakaway that I bought for about $230 from I believe, Kolb several years ago. They did not build that one. Spruce carried them as well. If it works, it is a bargain and should be on every Kolb. Makes life a lot easier.Larry
On Wed, Mar 22, 2017 at 7:18 PM, George Helton <gdhelton(at)gmail.com (gdhelton(at)gmail.com)> wrote:
George H.
14GDH
Have a great day!
Boyd y
Have a great day!
14GDH
> Sent from my iPhone
>> HTML Version:
>> Text Version:
ceengland7(at)gmail.com
PostPosted: Wed Mar 22, 2017 6:42 pm    Post subject: Kolb-List Digest: 0 Msgs - 03/21/17 Reply with quote
Feedback:
My primary experience is with heavier homebuilts, so this might not be a concern with the lower landing speeds of Kolbs. But in heavier a/c, the springs are in compression instead of tension, and look more like the attached image (pulled from a search for 'storm door spring').
Reason for using this style is that if the spring itself breaks, the Kolb-supplied spring will release the tailwheel & you'll lose steering. With the storm door spring, the 'omega' shaped brackets looped through the spring capture the broken spring and the cable just has an extra inch of so of extra slack. They also limit spring travel. The Kolb-supplied spring has no limit, and will continue to expand if the pivot is sticky enough.
FWIW,
Charlie
George H.
14GDH
Have a great day!
Boyd y
Have a great day!
14GDH
 Filesize:  15.15 KB
 Viewed:  8535 Time(s)
PostPosted: Wed Mar 22, 2017 7:16 pm    Post subject: Kolb-List Digest: 0 Msgs - 03/21/17 Reply with quote
Been using compression springs for a long time.
Titus, Alabama\\\
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England
Sent: Wednesday, March 22, 2017 9:44 PM
Subject: Re: Re: Kolb-List Digest: 0 Msgs - 03/21/17
Feedback:
FWIW,
Charlie
George H.
14GDH
Have a great day!
Boyd y
Have a great day!
14GDH
 Filesize:  309.99 KB
 Filesize:  303 KB
