BobbyPaulk(at)comcast.net Guest
Posted: Mon Mar 13, 2017 7:42 am Post subject: Tack vs Hobbs |
Getting back to the Tach vs Hobbs
My Pitts had a Tach calibrated for 2450 RPM to equal an hour.
Flight time was only accurate if you kept that RPM. Most times I was throttled back to 1900 and 2000 rpm to fly cross country with slower planes. When I accumulated 500 hrs plus on the Tach the actual flight time was over 700 hours. If you want accurate flight time for logging, oil changes, and maintenance you should definitely use Hobbs time.
Bobby
Kellym
Posted: Mon Mar 13, 2017 8:30 am Post subject: Tack vs Hobbs |
That just brings up the debate...should your maintenance be based on
clock time, or accumulated rpms? If you are at low power, low rpms, you
probably prefer the latter.
On 3/13/2017 8:38 AM, BobbyPaulk(at)comcast.net wrote:
Bobby
KCHD |
alec(at)alecmyers.com Guest
Posted: Mon Mar 13, 2017 8:36 am Post subject: Tack vs Hobbs |
In Canada maintenance time is based on aggregate flight time, strictly wheels-up to wheels-down, so you have to use a clock or wristwatch even if you have a Hobbs meter. What does the FAA require?
| Quote: | On Mar 13, 2017, at 12:28 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
That just brings up the debate...should your maintenance be based on clock time, or accumulated rpms? If you are at low power, low rpms, you probably prefer the latter.
> Bobby
tshankland(at)sbcglobal.n Guest
Posted: Mon Mar 13, 2017 9:24 am Post subject: Tack vs Hobbs |
I'm flying a Zenith Zodiac 610HD with a Status Subaru engine. During the
build I decided I didn't want two sensors for oil pressure attached to the
engine. The idea of a T fitting with two sensors vibrating gave me thoughts
cracked fittings. My solution was to use the existing oil pressure gage. The
gage is electric and it is not difficult to determine the voltage present at
the gage input that indicates that the engine is running. I built a small
circuit that monitors that voltage turns the Hobbs meter on when a
sufficient pressure is present. This way the Hobbs only runs when the engine
is running and not just when the master switch is on.
Tim Shankland
yellowduckduo(at)gmail.co Guest
Posted: Mon Mar 13, 2017 11:17 am Post subject: Tack vs Hobbs |
One can always fit a squat switch on the landing gear. I set my EIS
tach threshold so it does not accumulate time below a specific rpm such
that it ignores warm up and ground maneuvering. With my geared engine,
it also ignores flight time when I do power off landings though.
My most successful option by far though was to marry a former tower
controller who just can't break the habit of recording off and on
times...
Ken
On 13/03/2017 12:33 PM, Alec Myers wrote:
>> Bobby
cluros(at)gmail.com Guest
Posted: Mon Mar 13, 2017 12:21 pm Post subject: Tack vs Hobbs |
| Quote: | | Quote: | | In Canada maintenance time is based on aggregate flight time, strictly wheels-up to wheels-down, so you have to use a clock or wristwatch even if you have a Hobbs meter. What does the FAA require? |
For private aircraft in Canada (excepting 604) I can't think of a single maintenance item that is required to be done on a time basis. Yes you have to total the air time in the Journey Log (which any most handheld GPSs will keep track of for you), but since all required maintenance is based on calendar times, you can use whatever hourly time measure you want to when deciding what maintenance to do.
Sebastien
On Mar 13, 2017, at 12:14, C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)>
One can always fit a squat switch on the landing gear. I set my EIS tach threshold so it does not accumulate time below a specific rpm such that it ignores warm up and ground maneuvering. With my geared engine, it also ignores flight time when I do power off landings though.
My most successful option by far though was to marry a former tower controller who just can't break the habit of recording off and on times...
Ken
| Quote: | --> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)>
| Quote: | --> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
| Quote: | That just brings up the debate...should your maintenance be based on clock time, or accumulated rpms? If you are at low power, low rpms, you probably prefer the latter.
| Quote: | | Quote: | Getting back to the Tach vs Hobbs
| Quote: | | Quote: | My Pitts had a Tach calibrated for 2450 RPM to equal an hour.
| Quote: | | Quote: | Flight time was only accurate if you kept that RPM. Most times I was
| Quote: | | Quote: | throttled back to 1900 and 2000 rpm to fly cross country with slower
| Quote: | | Quote: | planes. When I accumulated 500 hrs plus on the Tach the actual flight
| Quote: | | Quote: | time was over 700 hours. If you want accurate flight time for logging,
| Quote: | | Quote: | oil changes, and maintenance you should definitely use Hobbs time.
| </==========================; - The AeroElectric-List Email Fors.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroEl====================================================bsp; - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_==========================; - NEW MATRONICS LIST W===================================================http://www.matronics.com/contr============================================
Posted: Mon Mar 13, 2017 12:34 pm Post subject: Tack vs Hobbs |
I wasn't suggesting that Canadian aircraft are subject to any particular maintenance or inspection requirements. Rather, that when they are, the relevant "run time" that has to be accounted for is wheels-up to wheels-down.
Let me as the question again: when the FAA mandates usage-based inspection or maintenance (for instance, mandatory 100 hour inspections for aircraft used for instruction) - what is the time that is counted towards those 100 hours? Is it engine run time, or air time, or tach time, or some other measure?
On 13Mar2017, at 4:17 PM, Sebastien <cluros(at)gmail.com> wrote:
| Quote: | > In Canada maintenance time is based on aggregate flight time, strictly wheels-up to wheels-down, so you have to use a clock or wristwatch even if you have a Hobbs meter. What does the FAA require?
Sebastien
On Mar 13, 2017, at 12:14, C&K <yellowduckduo(at)gmail.com> wrote:
Ken
>>> Bobby
donjohnston
Posted: Tue Mar 14, 2017 3:48 am Post subject: Re: Tack vs Hobbs |
| alec(at)alecmyers.com wrote: | | Let me as the question again: when the FAA mandates usage-based inspection or maintenance (for instance, mandatory 100 hour inspections for aircraft used for instruction) - what is the time that is counted towards those 100 hours? Is it engine run time, or air time, or tach time, or some other measure? |
When I had a TC aircraft, every shop used tach time. Not a single maintenance facility ever looked at the hobbs meter unless they needed the total airframe hours.
I can't say if there's a FAR enforcing that though and if there is, which one.
Posted: Tue Mar 14, 2017 11:25 am Post subject: Tack vs Hobbs |
At 03:32 PM 3/13/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com>
Don't know what the suggestion is today but when
we owned 1K1, only our revenue generating aircraft
were subject to 100 hour inspections . . . by what
ever means was fitted to the panel.
The J-3, with no electrical system and rudimentary
tach was serviced based on rental time. An old
Mooney was golden using tach time. The reset of
the TC fleet had hobbs meters . . . some
in addition to tach time but in our neck of the
world, the Hobbs was preferred both for maintenance
and billing practices.
It was explained to me that there was nothing magic
about inspecting every 100.00 plus or minus 0.01
hours. It was only necessary that the inspections
be done regularly in that general time frame.
Of course, tach hours are really engine revolution
counters. Hour recording tachs were spin-offs from
automobile speedometers where revolutions were directly
related to miles traveled.
Posted: Tue Mar 14, 2017 11:32 am Post subject: Tack vs Hobbs |
Good to know.
Someone else was kind enough to point me towards 14 CFR 1.1:
"Time in service, with respect to maintenance time records, means the time from the moment anaircraft leaves the surface of the earth until it touches it at the next point of landing."
On 14Mar2017, at 3:20 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
kjashton(at)vnet.net Guest
Posted: Tue Mar 14, 2017 12:43 pm Post subject: Tack vs Hobbs |
You are correct, Sir. One of the rites of passage to being a pilot is to learn the difference between “flight time” and “time in service”.
| Quote: | Flight time means:
(1) Pilot time that commences when an aircraft moves under its own power for the purpose of flight and ends when the aircraft comes to rest after landing; or
https://www.law.cornell.edu/cfr/text/14/1.1
| Quote: | On Mar 14, 2017, at 3:29 PM, Alec Myers <alec(at)alecmyers.com> wrote:
bobsv35b(at)aol.com Guest
Posted: Tue Mar 14, 2017 4:48 pm Post subject: Tack vs Hobbs |
The FAA only requires that time for maintenance purposes be listed from actual lift off to actual touchdown. The engine recording tachometer has been accepted as a legal substitute for actual lift off to touch down figure. It all depends on what you think is most convenient for you. Many helicopters use a switch on the collective. Others use tach time. Either could probably be supprted at a hearing.
Almost all airlines use lift off to touch down times.
Happy Skies,
Old Bob
