billhuntersemail(at)gmail Guest
Posted: Wed Mar 08, 2017 5:16 pm Post subject: D-Sub Connectors and |
Hi All,
I am wiring my Infinity Grips to my panel and I want to install them with a
connector as opposed to hard wired.
I bought this D-Sub 15 pin connector:
https://www.amazon.com/gp/product/B007R2JGOU/ref=oh_aui_search_detailpage?ie
=UTF8&psc=1
I do not like the connectors with the metal tap on something so small (makes
me use too many bad words in the process) so I would greatly prefer to use
the M39029/58-360 and M39029/57-354 connectors because I already have the
Eclipse crimp tool.
Does anyone know if these connectors will insert into the D-Sub 15 pin
connector I purchased? If not what connector should I buy to use with the
M39029/XXXX?
THANKS!!!
Bill Hunter
enginerdy(at)gmail.com Guest
Posted: Wed Mar 08, 2017 6:04 pm Post subject: D-Sub Connectors and |
I am not recommending this for your airplane, but when I have to take small-gauge wire into a screw terminal, I strip twice the length, double it back, and give it a gentle twist.
That way you're working with twice the amount of wire as before for the screw to grab.
Hope someone can answer your pin contact question, but just throwing that out for future consideration.
Daniel
| Quote: | On Mar 8, 2017, at 7:07 PM, William Hunter <billhuntersemail(at)gmail.com> wrote:
Hi All,
=UTF8&psc=1
Eclipse crimp tool.
M39029/XXXX?
THANKS!!!
Bill Hunter
Posted: Wed Mar 08, 2017 6:19 pm Post subject: D-Sub Connectors and |
At 07:07 PM 3/8/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: "William Hunter" <billhuntersemail(at)gmail.com>
Hi All,
=UTF8&psc=1
Eclipse crimp tool.
M39029/XXXX?
It should be fine . . .
Posted: Wed Mar 08, 2017 6:30 pm Post subject: D-Sub Connectors and |
That is the answer I was looking for. Thanks Bob!!! That is the answer I was looking for. Thanks Bob!!
Bill Hunter
On Mar 8, 2017 6:25 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote: | Quote: | At 07:07 PM 3/8/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: "William Hunter" <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)>
Hi All,
=UTF8&psc=1
Eclipse crimp tool.
M39029/XXXX?
