billhuntersemail(at)gmail Guest
Posted: Fri Mar 03, 2017 6:00 am Post subject: M27500 Shielded Wire For Strobe |
Greetings,Â
I am wiring a Velocity composite aircraft.Â
For my Whelen HDACF strobe light circuit I was planning on using the gold colored copper strand lamp cord from Home Depot... just kidding... I am actually planning on using Tefzel M22759/16 wire 18 guage from the CB to the overhead switch and then from the switch way back to the strobe unit mounted on the firewall (pusher airplane).Â
Then... I read "somewhere" that the M27500 Shielded wire is recommended for this application so as to suppress the noise.Â
Is this really necessary?Â
THANKS!!!Â
Bill Hunter
Posted: Fri Mar 03, 2017 6:48 am Post subject: M27500 Shielded Wire For Strobe |
At 07:58 AM 3/3/2017, you wrote:
| Quote: | Greetings,Â
Is this really necessary? |
Shielding of wires breaks only ONE kind
of noise propagation mode. This mode is very weak
and then only applies to certain kinds of
fast rising antagonists. No such antagonists exist
on the DC power line to any modern piece of
electronics . . . if it DOES demonstrate such
antagonists, then those will be CONDUCTED into
the rest of the system whether the wire is shielded
or not . . . short answer:
No
Posted: Fri Mar 03, 2017 11:16 am Post subject: M27500 Shielded Wire For Strobe |
Wow... Bob and Simon I am very grateful for your time. I cannot contribute much back to this forum however on other forums where I have some tid bits of ignorance to expound upon I try to help where I can so as to "cyber pay it forward".Â
Yes it seemed odd to me to have to shield a DC supply wire to the power inputs of a DC unit. Output wires from the strobe box to the strobe lights on the wings could have a argument.Â
I will certainly twist the power feed wire pairs as suggested for this box.Â
I also have two Light Speed Plasma III ignition units and two aircraft batteries. Since Klaus recommends running the POS and NEG wires directly from the battery terminals (through a reset able CB) to the units I will also twist those pairs.Â
My power feeds from the associated CB to the radios is a very small run and there is no negative wire nearby to twist so I guess that is a wash.Â
I do have some other wires from DC CBs to switches and then to appliances such as landing /taxi/beacon /voltage regulators and some of those wires runs will be bundled next to the XPNDR /ADS-B /NAV/COM coaxial cables (using the coaxial cable Bob recommended). I suppose the shield on the coax will do the trick.Â
Bill Hunter
On Mar 3, 2017 09:56, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote: | Quote: | At 07:58 AM 3/3/2017, you wrote:
 No
Â
Posted: Fri Mar 03, 2017 2:45 pm Post subject: M27500 Shielded Wire For Strobe |
At 01:13 PM 3/3/2017, you wrote:
| Quote: | Wow... Bob and Simon I am very grateful for your time. I cannot contribute much back to this forum however on other forums where I have some tid bits of ignorance to expound upon I try to help where I can so as to "cyber pay it forward".Â
I also have two Light Speed Plasma III ignition units and two aircraft batteries. Since Klaus recommends running the POS and NEG wires directly from the battery terminals (through a reset able CB) to the units I will also twist those pairs. |
That's a bit of OVERKILL . . . strike that . . .
it's a LOT of overkill. Klaus and I had
had some discussions about it and he didn't
disagree with me but still seems to get some kind
of comfort/satisfaction from running wires directly
to batteries.
Failure mode effects analysis and simple probability
studies demonstrate that each ignition simply needs
its own power source with no chance of single failure
bringing down both ignition systems. A prime example
of yet another flavor of poor FMEA is illustrated
here: http://tinyurl.com/msfmldj
If I were putting Lightspeed (or any other pair
of engine support accessories) in a TC aircraft,
I think my DARs would be happy with one ignition
powered from the battery bus on its own breaker/fuse
and powering the other from the main bus . . it
too powered by its own protection. Ground the
accessories locally (metal airplane) or to the
grounding hub on the firewall (see Figure Z-15).
Twisting the power/ground pairs is of no value
in reduction of noise. If the accessory dumps
and excessive level of noise back to the bus then
shielding/twisting won't help . . . furhter, the
product would not pass DO-160 qualification
testing for installation on a TC aircraft.
| Quote: | | My power feeds from the associated CB to the radios is a very small run and there is no negative wire nearby to twist so I guess that is a wash. |
Scrap the twisting thing . . .
| Quote: | | I do have some other wires from DC CBs to switches and then to appliances such as landing /taxi/beacon /voltage regulators and some of those wires runs will be bundled next to the XPNDR /ADS-B /NAV/COM coaxial cables (using the coaxial cable Bob recommended). I suppose the shield on the coax will do the trick. |
Your filtering apples out of your sack of
oranges. Shields on coaxes have a completely
different task . . . they have nothing in
common with shielding as a noise abatement
device. Coaxes bundled with virtually
any other wires raises no concerns for
inter-system interference.
Posted: Fri Mar 03, 2017 4:08 pm Post subject: M27500 Shielded Wire For Strobe |
Thanks Bob for the valuable information!!!Â
Bill Hunter
On Mar 3, 2017 16:55, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote: | Quote: | At 01:13 PM 3/3/2017, you wrote:
  to batteries.
