schwartzcompany(at)att.ne Guest
Posted: Sun Mar 05, 2017 9:56 am Post subject: No Title |
Whether a new engine or an old one, if the engine has sat for an extended period of time there is the possibility of corrosion in the bearings. About the only two real problems with the M701p is case seal failure causing a big oil leak or bearing corrosion/ eventual sieze up.Even a zero time overhaul engine could suffer this fate if storage pod was not kept sealed properly. Beware new engines in pod if the rubber seal is gone. I would run the engine more (on the ground) keep checking oil.
Just my opinion
| | - The Matronics L29-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
