		gfhperry(at)gmail.com Guest
				 Posted: Tue Mar 07, 2017 6:56 pm    Post subject: Panel Mod |
				Hi All,
 I would like to change my round dial six pack of instruments for an MGL glass panel. As my Europa is on the British register, I will need to get approval for the change. Has anyone with a G reg Europa done this Mod? If so could you give me details?
 Thanks guys.
 Glenn Perry G-DLCB Classic Mono
		JonathanMilbank
  Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
				 Posted: Wed Mar 08, 2017 2:36 am    Post subject: Re: Panel Mod |
				Hi Glenn,
 I did a partial panel change to install a Dynon EFIS a couple of years ago. As far as I'm aware, changes on the panel are a matter between you and your LAA inspector.
 Best wishes.
 Jonathan
		brian.davies(at)clara.co. Guest
				 Posted: Wed Mar 08, 2017 3:26 am    Post subject: Panel Mod |
				Jonathon,
 You are quite right in saying that there is room for applying " Standard
 Aircraft Practice" when designing your panel when this is not specified in
 the build manual.  LAA leaflet TL 3.10 explains this.
 However, (there is always one these, isn't there!) there are some other
 things to consider.
 When your panel design was initially approved by the LAA they were required
 by the CAA to satisfy themselves that you had complied with the regulations
 regarding the minimum instrument fit for VFR flight in accordance with the
 ANO and also to check the same for engine instrumentation.  Once the LAA has
 approved your aircraft build the LAA then submits an Airworthiness Approval
 Note (AAN) to the CAA that is the basis of approval for your initial Permit
 to Fly.  Technically, if you modify your aircraft so that it no longer
 conforms to the condition it was in when that initial approval was granted,
 you have invalidated your Permit to Fly.  Hence the need for a Mods approval
 system in the UK.
 When fitting an EFIS the LAA will want to know that you have considered the
 failure situation of a system that now relies on electrical power in order
 to comply with the regulations.  This requires the fitment of a standby ASI,
 Altimeter and compass as a minimum.
 So, the safest route is to consult LAA engineering and your inspector before
 changing from a traditional six pack to an EFIS.
 Brian Davies
