Richard Pike
Posted: Fri Feb 24, 2017 2:55 pm Post subject: Hobbs meter? |
Not planning any electrical system for the Firefly, but would like to hook up a Hobbs meter. We already have one that came with the wreck that shows the actual time of the 447, and our current panel has a cutout for it.
But I do not know how to make it work w/o a 12V system. Anybody know how?
Here's a couple pictures - engine is on the mounts, piddling with the panel. Pictures are not that great. At least they are not too big...
203.78 KB |
12437 Time(s) |
226.16 KB |
12437 Time(s) |
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Herbgh(at)nctc.com Guest
Posted: Fri Feb 24, 2017 3:09 pm Post subject: Hobbs meter? |
Hey Richard...
Looking super!! Mig or tig? Herb
On 02/24/2017 04:55 PM, Richard Pike wrote:
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny."
Aristotle
Posted: Fri Feb 24, 2017 3:18 pm Post subject: Hobbs meter? |
If it is an actual Hobbs Hour Meter it should be good for 112 to 60 vdc.
_________________ John Hauck
Titus, Alabama |
Posted: Fri Feb 24, 2017 3:29 pm Post subject: Hobbs meter? |
Had a typo in my last msg.
Should have read 12-60vdc.
john
Titus, Alabama |
George Alexander
Posted: Fri Feb 24, 2017 4:01 pm Post subject: Re: Hobbs meter? |
| Richard Pike wrote: | (SNIP)Not planning any electrical system for the Firefly, but would like to hook up a Hobbs meter. (SNIP)
Richard:
Can't remember the size/value, but I had a setup like you want using a small diode/rectifier (from Radio Shack) and picked up the lighting coil. Like John Hauck said, the Hobbs doesn't require a precise voltage level or pure DC.
Worth what you paid for it as always....
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
Posted: Fri Feb 24, 2017 4:10 pm Post subject: Hobbs meter? |
Look for a battery powered Timer
Boyd
On Feb 24, 2017 3:57 PM, "Richard Pike" <thegreybaron(at)charter.net (thegreybaron(at)charter.net)> wrote: | Quote: | --> Kolb-List message posted by: "Richard Pike" <thegreybaron(at)charter.net (thegreybaron(at)charter.net)>
Richard Pike
Kingsport, TN 3TN0
Forgiving is tough. Being forgiven is wonderful.
http://forums.matronics.com/viewtopic.php?p=466606#466606
http://forums.matronics.com//files/p1050711_medium_436.jpg
http://forums.matronics.com//files/p1050710_medium_195.jpg
WIKI -
Richard Pike
Posted: Fri Feb 24, 2017 6:07 pm Post subject: Re: Hobbs meter? |
Neglected to mention in the original post that this is the original 1985 model 447 that came with a new (1985) Firestar back in the day, so it has the single points ignition/lighting coil/charging coil.
Also - since the earlier post, started cutting apart the original wiring harness and discovered a diode with obvious connectors that would hook up to the Hobbs/hour meter. I am guessing I would attach those to the charging coil rather than the lighting coil, because all I want is the pulse, and not a lot of voltage. Also, I assume that if I hook it up to the hour meter and nothing happens, since it is a diode, all I need to do is swap the connectors?
Thanks for all the help so far!
And PS to Herb: Oxy/Acetylene. Old School FTW.
Kingsport, TN 3TN0
ceengland7(at)gmail.com Guest
Posted: Fri Feb 24, 2017 6:39 pm Post subject: Hobbs meter? |
On 2/24/2017 8:07 PM, Richard Pike wrote:
Richard Pike
Kingsport, TN 3TN0
Richard,
I can't really see what model you've got, but all the actual Hobbs
meters I've ever played with are simple clocks, that run when you apply
voltage (for instance, through an oil pressure switch, or a landing gear
'squat switch'). Are you thinking about something like a Tiny Tach,
that has its own battery but senses ignition pulses?
Charlie
Richard Pike
Posted: Fri Feb 24, 2017 7:08 pm Post subject: Re: Hobbs meter? |
Tiny Tach is great, I have one on my MKIII, but it is bigger than a Hobbs, and we need something to cover the hole where the original Hobbs was in the panel. No way the Tiny Tach will fit. Not to mention that I would need to figure out how to add 216 hours to it....
Talked to the original owner of our Firestar a while ago, and he seemed to remember that he got that diode from Kolb, and they told him how to hook it up. But he wasn't sure... (Grin)
Will try hooking the Hobbs up to the charging coil, through the diode, and see what happens.
126.88 KB |
12399 Time(s) |
Kingsport, TN 3TN0
Posted: Fri Feb 24, 2017 8:28 pm Post subject: Hobbs meter? |
I didn't think that was a pic of a Tiny Tach, but I wondered if your
mixing up how the two devices function.
Good luck with it,
Charlie
On 2/24/2017 9:08 PM, Richard Pike wrote:
Richard Pike
Kingsport, TN 3TN0
dickk9(at)aol.com Guest
Posted: Sat Feb 25, 2017 7:32 am Post subject: Hobbs meter? |
Along with the diode, a full wave bridge would be better, you should connect a capacitor (22mf 180v) across the output to filter the pulses.
Dick
Richard Pike
Posted: Sat Feb 25, 2017 5:18 pm Post subject: Re: Hobbs meter? |
| dickk9(at)aol.com wrote: | Along with the diode, a full wave bridge would be better, you should connect a capacitor (22mf 180v) across the output to filter the pulses.
Dick
OK, I think I know what you are saying, but you are talking to an electronics Hottentot. Really. Do I just go to the local electronics supply store and ask for such? And then attach it between the connectors?
Thanks!
Kingsport, TN 3TN0
Richard Pike
Posted: Thu Mar 02, 2017 10:45 am Post subject: Re: Hobbs meter? |
The mail lady left me a padded envelope in the box today, and inside it I found this: from Dick Kuntzleman, who took the time and trouble to spoon feed an electronically ignorant old man.
Thank you Sir, you have made my day.
117.88 KB |
12292 Time(s) |
Kingsport, TN 3TN0
