One last question - almost
philperry9
PostPosted: Thu Feb 23, 2017 9:36 am    Post subject: One last question - almost Reply with quote
I'm about to close up this aft deck area to prep for the inspection. Before I do, I'm just going over everything one last time.
For those if you using the overhead console from Geoff, have any of you had experience with using an undersized hole in the bulkhead? Just curious how the airflow is...
I punched a 1" hole inside the 2" scat connector. I just couldn't bring myself to knocking a 2" hole in that bulkhead.
I also drilled a 1/8" drain hole to let any water drain out. I'll attach a photo so you can see.
I'm just curious if anyone else has done something similar with a 1" hole and I'm most curious about how happy you are with he airflow.
Phil
 Filesize:  65.79 KB
 Viewed:  3524 Time(s)
civengpe
PostPosted: Thu Feb 23, 2017 10:35 am    Post subject: One last question - almost Reply with quote
Phil,I used two 1" holes with 2"X1" bulkhead adapters.  The airflow seems very good to me.
Shannon
On Thu, Feb 23, 2017 at 11:35 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Phil
 Filesize:  122.94 KB
 Viewed:  3522 Time(s)
 Filesize:  456.34 KB
