pelletie1959(at)me.com Guest
edpav8r(at)yahoo.com Guest
Posted: Tue Feb 14, 2017 11:35 pm Post subject: Fwd: CNBTR connector |
Does the threaded collar unscrew from the cable-grip end of the connector body? If so, you may find one or more screws hidden under the collar that allow the body to be split. It seems to me that I once used a similar connector made by Hirose Electric of Japan that opened this way.
Eric
Posted: Wed Feb 15, 2017 2:05 am Post subject: Fwd: CNBTR connector |
At 05:36 PM 2/14/2017, you wrote:
I've not encountered that particular product
before. It APPEARS to be a plastic clone of
the Mil-C-5015 connectors with roots dating
back to WWII. If so, check as follows:
[img]cid:7.1.0.9.0.20170215034727.0539fdd8(at)aeroelectric.com.0[/img]
See if there is a threaded joint under
the shaded area. Unscrew the back-shell
from the connector body. The Threaded
ring that engages the mating connector
simply floats on the housing held in
place by the back-shell.
mating
34.37 KB |
6524 Time(s) |
[img]cid:7.1.0.9.0.20170215035930.05528b88(at)aeroelectric.com.1[/img]
mating
-I STAND CORRECTED -
Found a whole line of products from CNBTR that
includes some solder-cup, emulations (if not
exact clones) of a Mil-spec connector line.
I've ordered one in to take a peek
http://tinyurl.com/jdgnmtt
These are an interesting product with an
attractive price. I'm looking forward
to a closer look.
34.37 KB |
6524 Time(s) |
Posted: Wed Feb 15, 2017 7:00 am Post subject: Fwd: CNBTR connector |
Thank you Bob,
You're right for the threaded joint under the shaded area. To unscrew the back-shell from the connector body, we must let the male part in place in the female part. You place the male part in a vise and use a vise grip to unscrew the back-shell. A particularity you unscrew counter clockwise.
Daniel
Le 15 févr. 2017 à 05:02, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> a écrit :
<26db80.jpg>
mating
to a closer look.
Posted: Wed Feb 15, 2017 7:37 pm Post subject: Fwd: CNBTR connector |
At 08:58 AM 2/15/2017, you wrote:
| Quote: | Thank you Bob,
You're right for the threaded joint under the shaded area. To unscrew the back-shell from the connector body, we must let the male part in place in the female part. You place the male part in a vise and use a vise grip to unscrew the back-shell. A particularity you unscrew counter clockwise. |
Yeah, these appear to be a near-if-not-exact clone
of a legacy mil-spec connector. I'll know more about
them when the sample I ordered gets here. The
prices are certainly right . . .
jan_de_jong(at)casema.nl Guest
Posted: Thu Feb 16, 2017 1:53 am Post subject: Fwd: CNBTR connector |
Here the whole range, up to 65 pins:
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20170216014307&SearchText=y2m+connector
Interested in your conclusions..
Jan de Jong
Bob . . . |
Posted: Thu Feb 16, 2017 9:16 am Post subject: Fwd: CNBTR connector |
At 03:49 AM 2/16/2017, you wrote:
thanks! at first blush, these seem to be a close
cousin to M311X series connectors (solder cup)
otherwise identical and mates with M312X series
(crimp pins).
It would be really cool if these in fact do
mate with the M31XX devices.
