solenoid
markdonahue
PostPosted: Sun Feb 05, 2017 2:58 pm    Post subject: solenoid Reply with quote
This is not plane related, but a friend has a diesel engine installation in his craft. He has a solenoid that operates a glow plug during starting sequence (hold key in glow plug position for 15 seconds before turning to start). The pre heat was not working so he has replaced the solenoid per the part list on the manual drawing which lists as 24v. But the system is wired for 12v. So the question is will a 24 volt solenoid work with 12 volt input?
Mark Donahue
Mark Donahue
PostPosted: Sun Feb 05, 2017 3:45 pm    Post subject: Re: solenoid Reply with quote
Probably will not work. By solenoid, I assume that you mean relay. Once pulled in, a relay will hold with half voltage. The problem is pulling it in initially.
Joe Gores
