Engine plugs to identify
trigo(at)mail.telepac.pt
PostPosted: Sat Feb 04, 2017 4:32 am    Post subject: Engine plugs to identify Reply with quote
Guys
In the back of my Lycoming IO-540, near the Oil Filter, there are 2 plugs that I’m not sure what they are for.
I’m referring to those 2 which have the red female caps in the annexed photo.
May I have your help to identify them?
Carlos
 Filesize:  561.96 KB
 Viewed:  8785 Time(s)
jesse(at)saintaviation.co
PostPosted: Sat Feb 04, 2017 5:59 am    Post subject: Engine plugs to identify Reply with quote
The big one is the mechanical tach drive. They sell caos for that if it leaks oil. Many planes I see don't have the cap and don't leak.
The small one I would need to see with the cap off. It is possibly an oil pressure line port.
Jesse SaintSaint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Feb 4, 2017, at 7:32 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
<![endif]--> <![endif]-->
Guys
Carlos
<Engine back plugs to identify.JPG>
PostPosted: Sat Feb 04, 2017 11:30 am    Post subject: Engine plugs to identify Reply with quote
Thanks Jesse
The small (lower) one is a male AN6 flared tube fitting, which I intend to plug with a AN929 plug.
CT
Enviado do meu iPhone
No dia 04/02/2017, às 13:58, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> escreveu:
C: 352-427-0285
F: 815-377-3694
Guys
Carlos
Kelly McMullen
PostPosted: Sat Feb 04, 2017 6:40 pm    Post subject: Engine plugs to identify Reply with quote
An AN6 fitting is not small. They are used for thinks like hoses to the oil cooler., Have you looked at the plans, FF1 if I remember correctly points out all the fittings you install. Then check the FF section for oil system to be sure you have all those fittings identified.
-sent from the I-droid implanted in my forearm
On Sat, Feb 4, 2017 at 12:27 PM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Thanks Jesse
CT
C: [url=tel:(352)%20427-0285]352-427-0285[/url]
F: [url=tel:(815)%20377-3694]815-377-3694[/url]
Guys
Carlos
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
PostPosted: Sat Feb 04, 2017 7:50 pm    Post subject: Engine plugs to identify Reply with quote
From looking at an overhaul manual, it looks like sometimes that port is used for a spring-and-ball oil cooler bypass, and sometimes for an oil cooler return. It's too small for that in this case, I think. If you have both of your AN8 lines already in for the oil cooler, then this should get capped.
Jesse Saint
352-427-0285
On Feb 4, 2017, at 9:38 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
Thanks Jesse
CT
Guys
Carlos
PostPosted: Sun Feb 05, 2017 4:52 am    Post subject: Engine plugs to identify Reply with quote
That’s the problem Kelly
The Van’s manual doesn’t explain all the fittings I found in the engine.
I did install the oil system according to FF section, but after connecting the oil pressure and both Oil cooler in and out, these 2 plugs are free.
Well, the higher one is indeed the Tachometer connection, which I will not use because I’m using the Garmin RPM sensor in the Magneto.
So, I think I’ll leave the lower one with this red cap, or perhaps close it with the AN929 plug.
Carlos
De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Kelly McMullen
Enviada: Sunday, February 5, 2017 2:38 AM
Para: rv10-list(at)matronics.com
Assunto: Re: Engine plugs to identify
Thanks Jesse
CT
Jesse Saint
Guys
Carlos
PostPosted: Sun Feb 05, 2017 4:54 am    Post subject: Engine plugs to identify Reply with quote
Thanks Jesse
Indeed I have both lines for the Oil Cooler connected according Van’s manual, so I will cap this.
If anyone else knows better what this is for, I am all ears …
Carlos
De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Jesse Saint
Enviada: Sunday, February 5, 2017 3:49 AM
Jesse Saint
352-427-0285
Thanks Jesse
CT
Jesse Saint
Guys
Carlos
PostPosted: Sun Feb 05, 2017 5:28 am    Post subject: Engine plugs to identify Reply with quote
Definitely DO NOT just leave the red cap on the oil port. You want a strong cap for it.
C: 352-427-0285
F: 815-377-3694
On Feb 5, 2017, at 7:51 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Carlos
De: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] Em nome de Kelly McMullen
Para: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
Thanks Jesse
CT
Jesse Saint
Guys
Carlos
Kelly McMullen
PostPosted: Sun Feb 05, 2017 5:47 am    Post subject: Engine plugs to identify Reply with quote
I agree. If you can't find a purpose for it in the overhaul or parts manual, definitely needs an AN cap. Plastic caps are only for shipping. They don't hold pressure and won't tolerate heat.
On Sun, Feb 5, 2017 at 6:28 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
Carlos
Assunto: Re: RV10-List: Engine plugs to identify
Thanks Jesse
CT
Jesse Saint
Guys
Carlos
Kelly McMullen
KCHD
PostPosted: Sun Feb 05, 2017 5:53 am    Post subject: Engine plugs to identify Reply with quote
Ok, just did it!
And for the Tachometer connection I won’t use, where can I buy a cap for this?
CT
Enviada: Sunday, February 5, 2017 1:28 PM
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Carlos
Thanks Jesse
CT
Jesse Saint
Guys
Carlos
PostPosted: Sun Feb 05, 2017 6:38 am    Post subject: Engine plugs to identify Reply with quote
https://m.aircraftspruce.com/catalog/inpages/tachcap.php?clickkey=15828
C: 352-427-0285
F: 815-377-3694
On Feb 5, 2017, at 8:53 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Ok, just did it!
CT
De: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] Em nome de Jesse Saint
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Carlos
Thanks Jesse
CT
Jesse Saint
Guys
Carlos
