Ttail
Posted: Fri Jan 27, 2017 4:01 pm Post subject: CJ6 Neutral Trim light |
Searched through the various manuals and couldn't find anything on where and how to set up the Neutral Elevator trim light on the CJ6. Anyone have anything on this ?
airmanv2
Joined: 01 Dec 2013 Posts: 49 Location: France - Normandy
Posted: Thu Feb 09, 2017 12:45 am Post subject: Re: CJ6 Neutral Trim light |
Hello,
You have to check in the radio compartment, behind the rear seat.
Open the back seat access, and look on the right and down side on the frame .
You will see the 2 cables of the tab trim .
the lower cable go through the neutral switch (check picture)
You must have a device clamped on the cable , when moving trough it activate it.
mine was broken and i replaced it by a lead device, from a fishing shop, clamped on the cable . (after aligned the trim and make a colored point on the cable, to notice the neutral position)
Adjusted to go through the switch.
if switch is ok and bulb on the green trim indicator are good, it will be lighted when neutral adjusted.
Bruno
1.44 KB |
13678 Time(s) |
4.03 KB |
13678 Time(s) |
1.38 MB |
13678 Time(s) |
_________________ Fly safe |
Clouddog
Posted: Thu Feb 09, 2017 7:21 am Post subject: CJ6 Neutral Trim light |
Interesting, my neutral trim switch is located on left side of aircraft behind the rear cockpit panel forward of the rear cockpit pulleys. I also used a small lead fishing line weight which I crimped to the trim cable. I filed the lead down so it was a bit pointed on both ends so it would pass smoothly through the switch.
On Feb 9, 2017 02:48, "airmanv2" <bruno.blanchard2(at)gmail.com (bruno.blanchard2(at)gmail.com)> wrote: | Quote: | --> Yak-List message posted by: "airmanv2" <bruno.blanchard2(at)gmail.com (bruno.blanchard2(at)gmail.com)>
Hello,
Bruno
Fly safe
http://forums.matronics.com/viewtopic.php?p=465911#465911
http://forums.matronics.com//files/olive_ouverte_161.jpeg
http://forums.matronics.com//files/olive_peche_trim_206.jpeg
http://forums.matronics.com//files/trim_neutre_switch_cj6_444.jpg
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
wlannon(at)shaw.ca Guest
Posted: Thu Feb 09, 2017 10:52 am Post subject: CJ6 Neutral Trim light |
Hi Greg;
You are describing the location correctly, certainly for the CJ as “left side of the aircraft”.
Previous poster may be referring to different aircraft but most likely is simply describing incorrectly as “open back seat access, look to the right”. In both cases it is the left side of the aircraft. In aviation left & right is always as the pilot sees it.
Cheers;
Walt
Sent: Thursday, February 09, 2017 7:20 AM
Subject: Re: Re: CJ6 Neutral Trim light
Hello,
Bruno
Fly safe
WIKI -
www.avast.com
jblake207(at)comcast.net Guest
Posted: Thu Feb 09, 2017 10:53 am Post subject: CJ6 Neutral Trim light |
Cloud Dog, I think I just heard you volunteer to fix mine next week. JB
To: yak-list(at)matronics.com
Sent: Thursday, February 9, 2017 9:20:40 AM
Hello,
Bruno
Fly safe
WIKI -
Looigi
Joined: 20 Apr 2015 Posts: 81 Location: Christchurch, New Zealand
Posted: Thu Feb 09, 2017 3:56 pm Post subject: CJ6 Neutral Trim light |
If things are “As the pilot sees it”, then the previous poster was correct. If it is behind the pilot, then for the pilot to see it, he would have to turn around and face the back of the plane!
Yep, my Airforce Instructor called me a smart ass when he told me the same thing, and I asked why the engines on large aircraft weren’t numbered the other way around…… Oh how we laughed.
| Quote: | On 10/02/2017, at 7:51 AM, Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
Hi Greg;
Cheers;
Walt
This email has been checked for viruses by Avast antivirus software. www.avast.com
Clouddog
Posted: Thu Feb 09, 2017 5:43 pm Post subject: CJ6 Neutral Trim light |
Well then, this explains a lot more. I saw the word " Air Farce" . Left/Right, Up/Down,This Way/ That Way. All sooooo confusing for the Air Force Boys and Girls. Us Army guys have to keep it simple. Pull up on the collective you go up, push down on the collective you go down. We have to keep it simple, we're Army!? Dang I love this inter-service rivalry! Oh do I need to mention the ARMY finally beat Navy after 15 years! Can't say much about the Marines. After all they are Marines! I hear they are STILL looking for a few good men. Fly safe and keep the greasy side down . ( That would be pointing toward the earth for the Air Force guys)!!
On Feb 9, 2017 5:59 PM, "Chris & Diane Burton" <cdoburton(at)gmail.com (cdoburton(at)gmail.com)> wrote: | Quote: | If things are “As the pilot sees it”, then the previous poster was correct. If it is behind the pilot, then for the pilot to see it, he would have to turn around and face the back of the plane!
| Quote: | On 10/02/2017, at 7:51 AM, Walter Lannon < Hi Greg;
Cheers;
Walt
www.avast.com
Posted: Thu Feb 09, 2017 7:10 pm Post subject: CJ6 Neutral Trim light |
Good one! LOL, Does that mean pilots are not too bright?
Walt
From: Chris & Diane Burton (cdoburton(at)gmail.com)
Sent: Thursday, February 09, 2017 3:54 PM
Hi Greg;
Cheers;
Walt
www.avast.com
www.avast.com
Ernie
Posted: Fri Feb 10, 2017 8:09 am Post subject: CJ6 Neutral Trim light |
Thats why us sailors use Port and Starboard.
On Thu, Feb 9, 2017 at 10:09 PM, Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
| Quote: | Good one! LOL, Does that mean pilots are not too bright?
Walt
Hi Greg;
Cheers;
Walt
www.avast.com
www.avast.com
Looigi
Posted: Fri Feb 10, 2017 1:14 pm Post subject: Re: CJ6 Neutral Trim light |
I am just an Aircraft Engineer Walt so I am not qualified to comment.
What was that old saying about monkeys riding bikes?
Friendly rivalry aside guys, I love this forum and the way you guys are willing to share your own experience and wisdom.
cjpilot710(at)aol.com Guest
Posted: Fri Feb 10, 2017 7:57 pm Post subject: CJ6 Neutral Trim light |
AH yes, BUT do you know where the words "port" & "starboard" actually came from?
Pappy
In a message dated 2/10/2017 11:10:48 A.M. Eastern Standard Time, erniel29(at)gmail.com writes:
| Quote: | Thats why us sailors use Port and Starboard.
Walt
Hi Greg;
Cheers;
Walt
www.avast.com
www.avast.com
Ttail
Posted: Sun Feb 12, 2017 9:18 pm Post subject: Re: CJ6 Neutral Trim light |
Thanks for the input Gents I am on to it.
