dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Thu Dec 29, 2016 8:16 am Post subject: MT Propeller Torque |
Re-installing my MT propeller after an overhaul and I cannot find the torque numbers. MT is closed until Jan. 9th here in the US and in Germany. Does anyone here know what the correct torque is? I think it is in the mid to upper 60's (foot pounds), but not sure.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
philperry9
Posted: Thu Dec 29, 2016 8:47 am Post subject: MT Propeller Torque |
The answer is it depends....
For the prop most of us are using it's the MTV12B/193-53.
300 HP and down, that prop gets 63-66 ft-lb.
300 HP or above, that prop gets 90-100 ft-lb.
Here is a link to the document with english on the right side.
http://www.mt-propeller.com/pdf/manuals/e-124.pdf
You have to look at the model number on your prop to determine bolts used in your flange. (That's page 9)
Then you can find the torque for them on your specific HP. (That's on page 19).
Phil
On Thu, Dec 29, 2016 at 10:16 AM, dmaib(at)me.com (dmaib(at)me.com) <dmaib(at)me.com (dmaib(at)me.com)> wrote:
| Quote: | --> RV10-List message posted by: "dmaib(at)me.com (dmaib(at)me.com)" <dmaib(at)me.com (dmaib(at)me.com)>
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=464470#464470
br> fts!)
r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com
w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com
e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
" rel="noreferrer" target="_blank">www.mrrace.com
WIKI -
dmaib@me.com
Posted: Thu Dec 29, 2016 9:39 am Post subject: Re: MT Propeller Torque |
Thanks Phil. That is the info I needed. Wolfgang from MT Germany responded to an email I sent at the same time you did and confirms it is 63 to 66 ft. lbs. for my prop/engine. They are closed for the holidays, but he apparently checks his email!
RV-10 #40559
