Plexi delamination.
wdaniell.longport(at)gmai
PostPosted: Thu Dec 22, 2016 4:47 am    Post subject: Plexi delamination. Reply with quote
I have a good bond everywhere except an are about 1.5 inches long but about 1/2 inch which is to say that I have 1.5 inches with just 1/4 inch of bond.  This is on the forward edge of the door plexi.
I tried drilling and injecting from the back but it appears it's not a void but a de-lamination and the glue wont flow in.
So what I was thinking it to do a 2 ply lay up over the joint between the door and the forward edge of the plexi ith araldite forming the the bond between the bid and the plexi.  Does anyone have a comment on this?
Will
HJ 460
PS started the engine/airmaster over the weekend with the Dynon connected everything works!  And my 14 year project has a name "HJ 460" and I have a trailer.
William Daniell
LONGPORT
+57 310 295 0744
SPURPURA
PostPosted: Thu Dec 22, 2016 8:10 am    Post subject: Re: Plexi delamination. Reply with quote
I would not worry about it,sounds like a small anomaly.If it becomes a problem later then you can repair it.
N951EU - Tri-gear & 912ULS, N77EU- Mono & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY.
