Audio Isolation Amplifier Boards
nuckollsr
PostPosted: Sat Nov 26, 2016 9:35 am    Post subject: Audio Isolation Amplifier Boards Reply with quote
I've had some requests for the bare etched circuit board called out in the DIY amplifier project featured at http://tinyurl.com/hn28p2q
Unfortunately, there is a minimum quantity for fabricating these. If I could sell three more boards at $25 each postage paid, I would be wiling to bring another batch of these in house.
This was probably the most successful DIY project on the AeroElectric website. I think we sold about 80 of those boards over the years.
art(at)zemon.name
PostPosted: Sat Nov 26, 2016 1:11 pm    Post subject: Audio Isolation Amplifier Boards Reply with quote
I'm dim. What is an Audio Isolation Amplifier used for? Which is oblique way of asking, do I need one for my plane?
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
ceengland7(at)gmail.com
PostPosted: Sat Nov 26, 2016 2:58 pm    Post subject: Audio Isolation Amplifier Boards Reply with quote
    -- Art Z.
https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
Hi Art,
They can have two potential uses. If you open the .pdf file from Bob's link, you'll see multiple sources listed that feed into one destination. This is 'summing' function, that allows combining multiple audio sources while maintaining isolation of the sources from each other. (If you just tie them all together, some or all may not be able to maintain a high enough level and/or have a clean signal. Like tying too many speakers in parallel to your stereo, or worse, tying the left and right outputs together.) With the isolation amp, you hear them all, but they don't interfere with each other.
The second potential function (not implemented with the components shown, but possible), is to supply 'gain', or amplification. Some signal sources may not be loud enough to match up with other sources, or you may need more volume in a loud cockpit than your radios or intercom can supply. With a few tweaks to the circuit, it could supply amplification, as well. (Verify with Bob that he's ok with doing this in this particular circuit.)
Charlie
cluros(at)gmail.com
PostPosted: Sat Nov 26, 2016 6:20 pm    Post subject: Audio Isolation Amplifier Boards Reply with quote
I was wondering the same thing so I had a look at the .pdf. As far as I can tell it's a budget way of tying in several radios to your intercom without spending thousands on an audio panel.
Sebastien
On Nov 26, 2016, at 13:58, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
-- Art Z.
email(at)jaredyates.com
PostPosted: Sat Nov 26, 2016 7:52 pm    Post subject: Audio Isolation Amplifier Boards Reply with quote
I use it to consolidate music, vhf nav audio, and dynon audio output into the single intercom input.
On Nov 26, 2016, at 21:18, Sebastien <cluros(at)gmail.com (cluros(at)gmail.com)> wrote:
Sebastien
-- Art Z.
merlewagner2
PostPosted: Sun Nov 27, 2016 3:58 am    Post subject: Re: Audio Isolation Amplifier Boards Reply with quote
Bob, you can sign me up for 2 boards.
Merle
KC1DNJ
General Radiotelephone
Commercial SEL
A & P
Building scale P51, rebuilding Tailwind W10
Eric M. Jones
PostPosted: Sun Nov 27, 2016 7:40 am    Post subject: Re: Audio Isolation Amplifier Boards Reply with quote
Bob,
Did you mean bare (not etched) circuit boards?
If so, a trip to you local PCB fab house will get you a truckload of boards in various thicknesses and single-double side configurations. Free.
Eric
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
rnjcurtis(at)charter.net
PostPosted: Sun Nov 27, 2016 8:58 am    Post subject: Audio Isolation Amplifier Boards Reply with quote
Sent from Mail for Windows 10
Sent: Sunday, November 27, 2016 10:43 AM
Subject: AeroElectric-List: Re: Audio Isolation Amplifier Boards
--> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net>
Bob,
He meant bare boards with no holes or copper.
 You drill your own holes mount the components,
and run wires to complete the circuits.
Be real Eric!  You know exactly what Bob meant
Quit trying to stir the pot!
Roger
Eric
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
David Lewis
PostPosted: Sun Nov 27, 2016 12:56 pm    Post subject: Re: Audio Isolation Amplifier Boards Reply with quote
Bob . . . I would be interested in purchasing two of these boards as well. Should I go to the web site to place the order or is there a specific email you want us to use for the request?
David Lewis
Burbank, CA
davidlewisstart(at)gmail.com
PostPosted: Mon Nov 28, 2016 9:13 am    Post subject: Audio Isolation Amplifier Boards Reply with quote
Bob,
Eric
No, our 9009-300-2A etched circuit board is
a component of the DIY audio isolation
amplifier project described in . . .
http://tinyurl.com/ngoo6hc
[img]cid:7.1.0.9.0.20161128110438.05579d20(at)aeroelectric.com.0[/img]
Perhaps the better term is 'unpopulated'. It looks
like this when you're done.
[img]cid:7.1.0.9.0.20161128110438.05579d20(at)aeroelectric.com.1[/img]
 Filesize:  150.26 KB
 Viewed:  21476 Time(s)
 Filesize:  151.14 KB
PostPosted: Mon Nov 28, 2016 9:15 am    Post subject: Audio Isolation Amplifier Boards Reply with quote
Correct. Notice too on the pictures that
there are gain setting resistors installed
in a socket. For audio sources with no
adjustable output, you can select the
resistor that levels that source with
the rest of your sources.
PostPosted: Thu Dec 08, 2016 5:55 pm    Post subject: Audio Isolation Amplifier Boards Reply with quote
I've had a number of folks express and interst in
acquiring the boards to the DIY audio Isolation
amplifier.
Interested purchases can be made from our
website at:
http://tinyurl.com/cgr42l5
Put your order details in the Commends/Special Rquests
box at the bottom of the form. The boards are $22 ea
plus first class postage of $2.25
I'll plan on ordering boards on Monday . . .
Assembly instructions for this project are available
at:
[img]cid:7.1.0.9.0.20161208145544.068ddb70(at)aeroelectric.com.2[/img]
[img]cid:7.1.0.9.0.20161208145544.068ddb70(at)aeroelectric.com.3[/img]
Bob . . .[url=??.htm] [/url]
Checked by AVG - www.avg.com
11/27/16
 Filesize:  150.26 KB
 Viewed:  21422 Time(s)
 Filesize:  151.14 KB
PostPosted: Sun Dec 11, 2016 8:53 pm    Post subject: Audio Isolation Amplifier Boards Reply with quote
--> AeroElectric-List message posted by: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
I've placed an order for the boards based
on requests received to date. The boards
are ordered in lots of 6. From the 2
lots just ordered I'll have 4 residual
boards available.
PostPosted: Sat Dec 17, 2016 5:44 am    Post subject: Audio Isolation Amplifier Boards Reply with quote
All boards requested have been shipped and
I'm out of boards.
donvansanten(at)gmail.com
PostPosted: Fri Dec 30, 2016 6:33 pm    Post subject: Audio Isolation Amplifier Boards Reply with quote
Bob,
Just noticed this. Would this be a good way to connect an xm roady music receiver to my audio panel?
Background, The roady has no volume control and is intended to plug into a cassette player using the supplied adapter. I wired it directly to my Garmin audio panel. It worked fine except The volume was lower than needed. I am changing to a PS Engineering PDA 360XR audio panel that has music input volume controls. I am not sure that the new install will have adequate volume.  Any ideas on how to increase the volume?
On Thu, Dec 8, 2016 at 1:00 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
amplifier.
website at:
at:
11/27/16
 Filesize:  150.26 KB
 Viewed:  21072 Time(s)
 Filesize:  151.14 KB
PostPosted: Fri Dec 30, 2016 6:43 pm    Post subject: Audio Isolation Amplifier Boards Reply with quote
Bob,
On Fri, Dec 30, 2016 at 6:32 PM, don van santen <donvansanten(at)gmail.com (donvansanten(at)gmail.com)> wrote:
Bob,
amplifier.
website at:
at:
11/27/16
 Filesize:  151.14 KB
 Filesize:  150.26 KB
