Fuel Valve Mounting Bracket
dfritz(at)bpgsim.com
PostPosted: Mon Nov 21, 2016 9:52 am    Post subject: Fuel Valve Mounting Bracket Reply with quote
My quick build fuselage came with the mounting bracket F1048C-1
installed facing down. There was a tag attached saying that it should
be reinstalled face up (the U facing up). They also sent me a new
bracket in case I messed up the installed one removing it. I am now in
the process of installing the fuel valve, an Andair unit. I have made a
mounting plate to rivet to the F1048C-1 so that mounting holes will
match the Andair valve. I am ready to flip the mounting bracket but
find the flush rivets on the aft end of the bracket are 1/4 inch from
the vertical panel of the seat mounting structure. I do not have a
drill that will fit in that close of an area and my rivet gun is too
wide to drive a rivet in that space. How have others made this change?
Dave
Kelly McMullen
PostPosted: Mon Nov 21, 2016 12:52 pm    Post subject: Fuel Valve Mounting Bracket Reply with quote
I cut the sides off the bracket and riveted two pieces of angle aluminum to get the width I need, got the Andair extension, mounted valve as low as possible, then cut the extension to required length. I did not want the valve up near the top of the tunnel, as that creates potential for vapor or air lock. I got the right angle fitting from Van's catalog to make the connection at the bottom of the valve.
-sent from the I-droid implanted in my forearm
On Mon, Nov 21, 2016 at 10:52 AM, David J. Fritzsche <dfritz(at)bpgsim.com (dfritz(at)bpgsim.com)> wrote:
--> RV10-List message posted by: "David J. Fritzsche" <dfritz(at)bpgsim.com (dfritz(at)bpgsim.com)>
My quick build fuselage came with the mounting bracket F1048C-1 installed facing down.  There was a tag attached saying that it should be reinstalled face up (the U facing up).  They also sent me a new bracket in case I messed up the installed one removing it.  I am now in the process of installing the fuel valve, an Andair unit. I have made a mounting plate to rivet to the F1048C-1 so that mounting holes will match the Andair valve.  I am ready to flip the mounting bracket but find the flush rivets on the aft end of the bracket are 1/4 inch from the vertical panel of the seat mounting structure.  I do not have a drill that will fit in that close of an area and my rivet gun is too wide to drive a rivet  in that space. How have others made this change?
Dave
br> fts!)
r> > /www.aeroelectric.com" rel="noreferrer" target="_blank">www.aeroelectric.com
w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com
e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
" rel="noreferrer" target="_blank">www.mrrace.com
WIKI -
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
glastar(at)gmx.net
PostPosted: Tue Nov 22, 2016 1:32 am    Post subject: Fuel Valve Mounting Bracket Reply with quote
Dave,
that is an interesting statement, as according plans facing down is correct. As I did another setup (Andair) I had to swap it as well; a long 3-4" drill bit and a good, deep mark in the center, did allow me to drill it out, slightly bend in the middle. I did use a bucking bar on both sides and had the mushroom set on the outside bucking bar (you need a helper!) with that approach I was able to set that last rivet however it took 2 attemps!
[img]cid:part1.06DD0867.ED6FB5E0(at)gmx.net[/img]
Werner
On 21.11.2016 18:52, David J. Fritzsche wrote:
--> RV10-List message posted by: "David J. Fritzsche" <dfritz(at)bpgsim.com> (dfritz(at)bpgsim.com)
 Filesize:  1.38 MB
 Viewed:  4437 Time(s)
PostPosted: Tue Nov 22, 2016 12:29 pm    Post subject: Fuel Valve Mounting Bracket Reply with quote
Kelly,
The only right angle fittings I can find in Van's catalog are tube/pipe.  Both my valve and filter have male tubing connections.  I would need a right angle with female tube connections on both ends.
Dave
David J. Fritzsche
Professor, Retired
Penn State
Dave
br> fts!)
WIKI -
Kelly McMullen
PostPosted: Tue Nov 22, 2016 5:53 pm    Post subject: Fuel Valve Mounting Bracket Reply with quote
It is called the F Swivel Tee. There is only one female fitting, as the other two are intended to have female flared fittings connected to them, like virtually all of the fuel system connections.
On Tue, Nov 22, 2016 at 1:29 PM, David J. Fritzsche <dfritz(at)bpgsim.com (dfritz(at)bpgsim.com)> wrote:
Kelly,
Dave
David J. Fritzsche
Professor, Retired
Penn State
Dave
br> fts!)
WIKI -
Kelly McMullen
KCHD
