Aluminum Neck-T-5 Fuel Distributor
hgmckay
PostPosted: Mon Nov 21, 2016 8:50 am    Post subject: Aluminum Neck-T-5 Fuel Distributor Reply with quote
I am replacing the rubber fuel lines on my Rotax 912 UL engine. There is a five barb aluminum fuel line distributor on top of the engine. Two of the barbed connectors on this fuel distributor have flow restrictors in them. One of the two barb connectors with restrictors has a small crack in it. I need to replace the entire distributor. Where can I find this aluminum fuel distributor?
Hugh G. McKay III, P.E. Fellow, L.M. ASCE
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net
http://www.wwegeo.com
Hugh.vcf
 Filename:  Hugh.vcf
 Filesize:  79 Bytes
 Downloaded:  610 Time(s)
Don Maxwell
PostPosted: Tue Nov 22, 2016 5:19 am    Post subject: Aluminum Neck-T-5 Fuel Distributor Reply with quote
Hugh, you may be referring to this assembly, depicted on page 21-2 of the Illustrated Parts Catalog, May 01/2009 (may be on a different page in other editions):
[img]cid:part1.8727F9DC.5F49E8C5(at)AbstractConcreteWorks.com[/img]
You should be able to buy all of the parts from Lockwood Aviation, of Sebring FL:  https://lockwood.aero/
 Filesize:  74.54 KB
 Viewed:  6089 Time(s)
