italianjon
Posted: Mon Nov 14, 2016 1:48 pm Post subject: Replacement/Re-use of Mil Spec Multi Pin Connectors |
Hi All,
I am hoping someone is more familiar than me with NATO Spec connectors.
I am installing Mode S/8.33 and a few other bits on my panel. Through the fire wall, for the signal / low power lines, I have 6026-18-32SN and 6026-18-32PN connectors. The coupling works really well and I would like to keep it if possible.
I am struggling to find a spec sheet for them, as it appears that the spec has been discontinued. I have found PT06A-18-32s but the pin layouts look different. I have found some 6026-18-32 connectors, but they are prohibitively expensive and all appear as recovered/reconditioned stock, without spec sheets.
Ideally I would like to re-use the connector and source new pins (both male and female) for it so that I can crimp new pins on to the new low power/signal lines and keep the connectors.
Does anyone have/know where I could get/simply could tell me the model of pins that I would need to order?
Best,
Jon
nigel_graham(at)m-tecque. Guest
Posted: Mon Nov 14, 2016 3:51 pm Post subject: Replacement/Re-use of Mil Spec Multi Pin Connectors |
Hi Jon,
Military grade hardware is prohibitively expensive - but you won't get
better. RS and Farnell used to supply these Amphenol connectors but I
suppose the demise of our defence industry means there is no longer a
market for them?
You can download a datasheet from these people but you'll need to register.
http://www.acalbfi.com/uk/Connectors-and-Cables/Circular/Connector/p/Circular-connector--602GB--MIL-DTL-26482---size-18--sockets--32-contacts--Olive-Drab-Cadmium/0000008D1M
Unless you already have the dedicated Amphenol crimping tool (also
prohibitively expensive) it might pay to get the solder-bucket pins
(these people supply them) - all you need is a good quality temperature
controlled soldering iron, a steady hand and younger eyes than I have.
Hope that helps.
Nigel
On 14/11/2016 21:48, italianjon wrote:
Quote: |
Hi All,
Best,
Jon
http://forums.matronics.com/viewtopic.php?p=462536#462536
