capedavis(at)yahoo.com Guest
Posted: Mon Oct 24, 2016 6:40 am Post subject: 7/16 x .028 shims |
Kolbers , On my Firefly construction Im told to cut two shims of 4130 7/16 x 028 I believe they will be about 1/8 each or less I dont have any tubing of that size laying around so i called Aircraft Spruce and they dont have any either the thinnest wall that they have is .035 so i thought maybe someone on the list might be able to send me a little piece by us mail wont cost much for shipping so can anyone help me out?thank u Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Herbgh(at)nctc.com Guest
Posted: Mon Oct 24, 2016 7:38 am Post subject: 7/16 x .028 shims |
Chris
I do not recall them..what is the purpose? Herb
On 10/24/2016 09:36 AM, chris davis wrote:
| Quote: | Kolbers , On my Firefly construction Im told to cut two shims of 4130 7/16 x 028 I believe they will be about 1/8 each or less I dont have any tubing of that size laying around so i called Aircraft Spruce and they dont have any either the thinnest wall that they have is .035 so i thought maybe someone on the list might be able to send me a little piece by us mail wont cost much for shipping so can anyone help me out?thank u Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny."
Aristotle
"Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter...
Posted: Tue Oct 25, 2016 8:14 am Post subject: 7/16 x .028 shims |
Herb the shims go on the 3/8 bolt that goes through th H tube so the flaperon arms can swivel freely .
On Oct 24, 2016, at 11:35 AM, Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote:
Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Aristotle
Posted: Tue Oct 25, 2016 9:38 am Post subject: 7/16 x .028 shims |
Chris
Those are short pieces of tubing that fit over the h section through bolt..Just a bit longer than the actuation levers are wide...Herb
On 10/25/2016 11:14 AM, chris davis wrote:
| Quote: | Herb the shims go on the 3/8 bolt that goes through th H tube so the flaperon arms can swivel freely .
Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Aristotle
Aristotle
Posted: Tue Oct 25, 2016 9:46 am Post subject: 7/16 x .028 shims |
the holes in the levers should be just large enough to allow the shims to slide freely through.. ..Herb
On 10/25/2016 12:36 PM, Herb wrote:
Chris
Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Aristotle
Aristotle
Aristotle
Posted: Tue Oct 25, 2016 7:15 pm Post subject: 7/16 x .028 shims |
Yes herb I know what they are I was just trying to locate a piece of tubing that size 7/16 x 028 as I said I don't have any and I call aircraft spruce and they don't have any 7/16 with a wall that thin 035 was the thinnest wall they sell so instead of buying a lot more than I need somewhere else I thought perhaps someone on the list might have a piece they could send me ? Get my drift? Thanks for the comeback if no one else responds I guess I will look elsewhere or maybe even ask Bryon at KOLB for a piece . Chris
On Oct 25, 2016, at 1:36 PM, Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote:
Chris
Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Aristotle
Aristotle
Posted: Wed Oct 26, 2016 5:19 am Post subject: 7/16 x .028 shims |
Chris
Looking at the plans..it would be hard to tell if it is a piece of tubing or just a flat washer.. I think Kolb went to all .035 in the Firefly fuselage to standardize it to all the other models. I will check my stock...and let you know...If not..betting Bryan can send you a couple of pre cut shims...for shipping cost ...Herb
On 10/25/2016 10:15 PM, chris davis wrote:
| Quote: | Yes herb I know what they are I was just trying to locate a piece of tubing that size 7/16 x 028 as I said I don't have any and I call aircraft spruce and they don't have any 7/16 with a wall that thin 035 was the thinnest wall they sell so instead of buying a lot more than I need somewhere else I thought perhaps someone on the list might have a piece they could send me ? Get my drift? Thanks for the comeback if no one else responds I guess I will look elsewhere or maybe even ask Bryon at KOLB for a piece . Chris
Chris
Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Aristotle
Aristotle
Aristotle
Posted: Wed Oct 26, 2016 6:06 am Post subject: 7/16 x .028 shims |
Herb, I guess that I will try Bryan. According to my plans it is a piece of tubing and I have tried to find a washer that only has an outside diameter of 7/16 and would have an inside diameter of 3/8 to no avail so I guess I will try KOLB.
Thanks for your input . Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
On Wednesday, October 26, 2016 9:24 AM, Herb <Herbgh(at)nctc.com> wrote:
Chris
| Quote: | Chris
| Quote: | Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Aristotle
Aristotle
Aristotle
Posted: Wed Oct 26, 2016 8:09 am Post subject: 7/16 x .028 shims |
I went to my tubing stash and did not find anything...Herb
On 10/26/2016 09:03 AM, chris davis wrote:
| Quote: | Herb, I guess that I will try Bryan. According to my plans it is a piece of tubing and I have tried to find a washer that only has an outside diameter of 7/16 and would have an inside diameter of 3/8 to no avail so I guess I will try KOLB.
Chris Davis
KXP 503 492 hrs
Glider Pilot
On Wednesday, October 26, 2016 9:24 AM, Herb <Herbgh(at)nctc.com> (Herbgh(at)nctc.com) wrote:
Chris
| Quote: | Chris
| Quote: | Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Aristotle
Aristotle
Aristotle
Aristotle
Posted: Wed Oct 26, 2016 8:21 am Post subject: 7/16 x .028 shims |
Chris
A bronze bushing might work? ACE hardware for one...Herb
Chris
Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Aristotle
Aristotle
Aristotle
Posted: Wed Oct 26, 2016 2:15 pm Post subject: 7/16 x .028 shims |
Herb I emailed Kolb and Bryan said he would send me some , thanks for your effort ..Chris
On Oct 26, 2016, at 12:09 PM, Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote:
Chris Davis
KXP 503 492 hrs
Glider Pilot
Chris
| Quote: | Chris
| Quote: | Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Aristotle
Aristotle
Aristotle
Aristotle
