Fuel Pump / Filter question
rowlandcarson(at)gmail.co
PostPosted: Sun Oct 23, 2016 8:22 am    Post subject: Fuel Pump / Filter question Reply with quote
On 2016-10-23, at 12:16, Wladimir Kummer <wladimirkummer(at)gmail.com> wrote:
Where is the most usual / most favorable location of the FACET fuel pump? Where do you put the filters? I’m planning the route of fuel lines from the tank to firewall.
Wladimir - page 6-1 of the Europa XS firewall-forward manual for the Rotax 912 says:
"The electric pump SS502 (stamped 40106 on one of the mounting flanges) is to be mounted in the port underfloor chamber situated in the baggage bay floor."
My fuel system is slightly non-standard but you can see how and where I mounted my fuel pump in photos on these pages of my build journal:
http://www.rowlandcarson.org.uk/aviation/europa_435/gascolator_to_pump.php
http://www.rowlandcarson.org.uk/aviation/europa_435/pump_to_sender.php
http://www.rowlandcarson.org.uk/aviation/europa_435/gascolator_inlet_pipe.php
http://www.rowlandcarson.org.uk/aviation/europa_435/fuel_system_wiring.php
Hope this is of some help.
in friendship
Rowland
SPURPURA
PostPosted: Mon Oct 24, 2016 3:26 am    Post subject: Re: Fuel Pump / Filter question Reply with quote
Looking at your photos,the fuel pipe may be in the way of the flap drive.
N951EU - Tri-gear & 912ULS, N77EU- Tri-gear & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY.
