Sticky start?
greg.barnhard@gmail.com
PostPosted: Sat Oct 15, 2016 1:49 pm    Post subject: Sticky start? Reply with quote
Hello everyone,
Please bear with me as I'm still pretty new to the Yak world and trying to wrap my head around everything.
The last couple of flights I did (last dozen or so) I had to push the start button multiple times (and while holding) to actually get the prop to turn over. As soon as I pushed the button I could hear the shower of sparks immediately but no start valve or air. The battery voltage was plenty good 24.5 - 25 volts at a minimum. I'm trying to figure out if this might be a solenoid issue or a sticky start valve. Any thoughts, suggestion, advice?
Thanks so much.
Greg
Yak 52W
hkgibby(at)yahoo.com
PostPosted: Sat Oct 15, 2016 2:14 pm    Post subject: Sticky start? Reply with quote
Hi Greg-
Sounds like your QDF-1 start solenoid/valve is sticking and failing. The lower pneumatic portion of the valve is very prone to corrosion. Craig Payne did a nice article for Red Alert a year or so ago that gives great advice on the care and feeding of the often forgotten QDF. Doug also sells a re-build kit for the lower portion. Try manually overriding the electrical (shower of sparks) side next start by pushing down on the tab on the valve (right firewall) and see how it responds. Two person operation of course. Maybe Craig or someone can post that article. I'll try to find it myself and send it to you offline.
Hoot
On Oct 15, 2016, at 2:49 PM, "greg.barnhard(at)gmail.com" <greg.barnhard(at)gmail.com> wrote:
Hello everyone,
Thanks so much.
Greg
Yak 52W
http://forums.matronics.com/viewtopic.php?p=461314#461314
Ernie
PostPosted: Sat Oct 15, 2016 2:34 pm    Post subject: Sticky start? Reply with quote
Low air pressure?
On Saturday, October 15, 2016, greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com) <greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)> wrote:
--> Yak-List message posted by: "[url=javascript:;]greg.barnhard(at)gmail.com[/url]" <[url=javascript:;]greg.barnhard(at)gmail.com[/url]>
Hello everyone,
Thanks so much.
Greg
Yak 52W
List" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
lank">http://wiki.matronics.com
PostPosted: Sat Oct 15, 2016 2:44 pm    Post subject: Re: Sticky start? Reply with quote
Ernie, the air pressure isn't low, almost always 5 on the gauge.
Hoot, that sounds about right. I'll have to try that. If you could find a link that would be awesome...in the mean time I'm going to search for that.
Is that the only major area that sees corrosion or are there other places I should look as well?
Thanks!
Greg
rmhou(at)yahoo.com
PostPosted: Sat Oct 15, 2016 3:23 pm    Post subject: Sticky start? Reply with quote
Flash your starter valve with WD40 should get you going for awhile, but you are likely to need a valve overhaul in the very near future.
Sent from Yahoo Mail on Android
On Sat, Oct 15, 2016 at 15:44, greg.barnhard(at)gmail.com
--> Yak-List message posted by: "greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)>
Thanks!
Greg
http://forums.matronics.com/viewtopic.php?p=461318#461318http://www.matronics.com/Navigator?Yak-Listhttp://forums.matr - NEW MATRONICS LIST WIKI -
_ http://wiki.matron -Mats.com/contribution" target="_blank">http://www.matronics.com/contribution==============
Viperdoc
PostPosted: Sat Oct 15, 2016 3:25 pm    Post subject: Sticky start? Reply with quote
Go to the RPA website. It will be in archieves.
Doc
On Oct 15, 2016, at 5:44 PM, "greg.barnhard(at)gmail.com" <greg.barnhard(at)gmail.com> wrote:
Thanks!
Greg
Viperdoc
dsavarese0812(at)bellsout
PostPosted: Sat Oct 15, 2016 3:56 pm    Post subject: Sticky start? Reply with quote
If it's a Yak 52, you're not going to like this job. If a CJ, it's a piece of cake.
Remove the air start valve and either disassemble and clean it or call Doug Sapp and order a new air start valve and replace it. There are set screws on the sides of the hex head.  So be sure to loosen them before you attempt to disassemble it.
If it's a Yak 52, there should be a small tab on the side which is used to manually engage the air start valve using the side of the sole of your shoe. If you decide to replace it, ask Doug if he has one with the tab on the side.
Dennis
From: "greg.barnhard(at)gmail.com" <greg.barnhard(at)gmail.com>
To: yak-list(at)matronics.com
Sent: Saturday, October 15, 2016 5:49 PM
Subject: Yak-List: Sticky start?
--> Yak-List message posted by: "greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)" <greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)>
Hello everyone,
Thanks so much.
Greg
Yak 52W
http://forums.matronics.com///www.matronics.com/Navigator?Yak-List" target="_blank">http://www.matronp; &nhttp://========================
PostPosted: Sat Oct 15, 2016 3:59 pm    Post subject: Sticky start? Reply with quote
Greg-
If you mean just the start system (which has few components) downstream of the QDF-1 then the next item is the air distributor (spider web of metal tubes "hub") on the engine accessory case which could cause starting issues but it is typically not an issue unless it has been tampered with as it is factory set. There are 9 individual air check valves (one on each cylinder) that can corrode. If one fails though it is a very obvious leak and the prop will stop on that cylinder. Upstream of the solenoid your main air valve can leak and I recommend you replace the steel needle valve with a SS one which Doug has. I am confident it is your QDF-1 once you rule out the Main air valve. The pneumatic system has 44 items which are ALL prone to corrosion and can cause different issues. Replace all springs and needle valves with Stainless Steel and rebuild, clean, change desiccant often and upgrade where possible to keep your system as healthy as possible. Do it all at once or over time but the pneumatic system probably causes by far the most gripes in our birds than any of the other aircraft systems combined. Fortunately Doug has all items you need to maintain and upgrade to SS and Jill can now rebuild gear/flap valves.
Good luck!!🍀
Hoot
On Oct 15, 2016, at 3:44 PM, "greg.barnhard(at)gmail.com" <greg.barnhard(at)gmail.com> wrote:
Thanks!
Greg
PostPosted: Sat Oct 15, 2016 6:46 pm    Post subject: Re: Sticky start? Reply with quote
Once the valve opens it starts just fine. The issue is getting the valve to open once the start button is pushed. It is on a Yak 52W, so I had a feeling none of this would be fun. Is the valve and solenoid separate or are they apart of the same unit aka replace one you're replacing both. I'm still learning about how this plane was cared for by the previous owner for the past 16 years (since new) so it's a learning experience. Thanks again for everyone's patience dealing with the new guy.
I'm doing a lot of work on it this winter and would prefer to get as much done as possible now while everything is opened up. It sounds like stainless is the way to go with the pneumatic system.
Thanks!
Greg
PostPosted: Sun Oct 16, 2016 3:36 am    Post subject: Sticky start? Reply with quote
The valve and solenoid are one unit and it is located in front of the left rudder pedal in the front cockpit on the firewall. I've attached a photo of the air start valve on a standard Yak 52. It's the same on a 52W. Except the rudder pedal will block the view (AND the ability to manually engage the air start valve). Notice in the photo there is a clamp around which mounts it on the firewall. It is the vertical cylinder looking thing. It's much more difficult to remove on the 52W because of the hydraulic brake pedals. The electrical connector is on the top of the unit. There are two pneumatic fittings. One on the bottom and one on the side.
The reason the valve won't open initially is because it is gunked up internally or the solenoid has become weak. Once you clean and reassemble it, you can test it on the bench with a 24 volt battery. If it doesn't open immediately when you test it, then I would suggest you replace it. Just don't reinstall it and then test it because if it's defective, you'll obviously have to remove it again and install a new one.
Dennis
Sent: Saturday, October 15, 2016 10:46 PM
Subject: Re: Sticky start?
Thanks!
Greg
http://forums.matronics.com/viewtopic.php?p=461328#461328http://www.matronics.com/Navigator?Yak-Listhttp://forums.mat - NEW MATRONICS LIST WIKI -
_ http://wiki.matro -Mats.com/contribution" target="_blank">http://www.matronics.com/contribution==============
Air_Start_Valve_Photo.pdf
 Filename:  Air_Start_Valve_Photo.pdf
 Filesize:  92.63 KB
 Downloaded:  652 Time(s)
PostPosted: Sun Oct 16, 2016 8:17 am    Post subject: Re: Sticky start? Reply with quote
Dennis, that's perfect. Thank you. If I may, what's your recommendation for a lubricant for the air system?
Greg
cjpilot710(at)aol.com
PostPosted: Sun Oct 16, 2016 8:39 am    Post subject: Sticky start? Reply with quote
Greg,
Try shooting a little mouse milk in it and moving the manual lever a few times. Or some WD40 or airtool oil too.
Jim "Pappy" Goolsby
PS Will be going out on the B24 on the 27th. How about you?
In a message dated 10/15/2016 10:47:53 P.M. Eastern Daylight Time, greg.barnhard(at)gmail.com writes:
--> Yak-List message posted by: "greg.barnhard(at)gmail.com" <greg.barnhard(at)gmail.com>
Thanks!
Greg
http://forums.matronics.com/viewtopic.php?p=461328#461328===============================================
_-= e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - NEW MATRONICS LIST WIKI -_-= - List Contribution Web Site sp;   ===================================================
byronmfox(at)gmail.com
PostPosted: Sun Oct 16, 2016 9:48 am    Post subject: Sticky start? Reply with quote
Doug Sapp recommends castor oil to lubricate the air system
Blitz Fox415-307-2405
On Oct 16, 2016, at 9:17 AM, "greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)" <greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)> wrote:
Greg
http://forums.matronics.com/viewtopic.php?p=461342#461342
<========================== - The Yak-List Email nics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List================================================
http://www.matronics.com/contribution<========================================
Ernie
PostPosted: Sun Oct 16, 2016 9:53 am    Post subject: Sticky start? Reply with quote
It's also recommended in the CJ maintenance and overhaul manuals.
On Sunday, October 16, 2016, Byron Fox <byronmfox(at)gmail.com (byronmfox(at)gmail.com)> wrote:
On Oct 16, 2016, at 9:17 AM, "[url=javascript:_e(%7B%7D,'cvml','greg.barnhard(at)gmail.com');]greg.barnhard(at)gmail.com[/url]" <[url=javascript:_e(%7B%7D,'cvml','greg.barnhard(at)gmail.com');]greg.barnhard(at)gmail.com[/url]> wrote:
--> Yak-List message posted by: "[url=javascript:_e(%7B%7D,'cvml','greg.barnhard(at)gmail.com');]greg.barnhard(at)gmail.com[/url]" <[url=javascript:_e(%7B%7D,'cvml','greg.barnhard(at)gmail.com');]greg.barnhard(at)gmail.com[/url]>
Greg
<=          - The Yak-List Email nics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List================================================
Viperdoc
PostPosted: Sun Oct 16, 2016 11:47 am    Post subject: Sticky start? Reply with quote
None. Everything we dump in there breaks down the cheep RU and Chinese rubber seals.
Doc
On Oct 16, 2016, at 11:17 AM, "greg.barnhard(at)gmail.com" <greg.barnhard(at)gmail.com> wrote:
Greg
Viperdoc
PostPosted: Sun Oct 16, 2016 2:40 pm    Post subject: Re: Sticky start? Reply with quote
Interesting information. I appreciate it.
Pappy, I missed the PS. I think I'm done for the year unless a slot opens up and they need someone. I'll be starting off in Florida so I will see you then!
Greg
