aslink
Posted: Sat Oct 15, 2016 11:06 am Post subject: HKS Exhaust Andy Style |
I created this stainless steel exhaust system from many pieces and manufacturers to fit within the limited parameters, the tube radii, expanded tube ends, and ball joints needed. I have this information if wanted. The system has not been tested for noise or vibration.
Andy
Your message is ready to be sent with the following file or link attachments:
Kolb HKS Oil Cooler
Kolb HKS Exhaust A
Kolb HKS Exhaust B
Kolb HKS Exhaust C
Kolb HKS Exhaust D
Kolb HKS Exhaust E
Kolb HKS Exhaust F
Note: To protect against computer viruses, e-mail programs may prevent sending or receiving certain types of file attachments. Check your e-mail security settings to determine how attachments are handled.
63.45 KB |
4836 Time(s) |
50.66 KB |
4836 Time(s) |
64.44 KB |
4836 Time(s) |
79.27 KB |
4836 Time(s) |
64.44 KB |
4836 Time(s) |
66.4 KB |
4836 Time(s) |
58.18 KB |
4836 Time(s) |
_________________ Andy |
russk50(at)gmail.com Guest
Posted: Sat Oct 15, 2016 4:46 pm Post subject: HKS Exhaust Andy Style |
That loox great! thanks for sending | Quote: | On Oct 15, 2016, at 3:05 PM, Andy and Sheila Slinkard <andysheila(at)eltopia.com (andysheila(at)eltopia.com)> wrote:
Andy
Your message is ready to be sent with the following file or link attachments:Kolb HKS Oil CoolerKolb HKS Exhaust AKolb HKS Exhaust BKolb HKS Exhaust CKolb HKS Exhaust DKolb HKS Exhaust EKolb HKS Exhaust FNote: To protect against computer viruses, e-mail programs may prevent sending or receiving certain types of file attachments. Check your e-mail class="Apple-converted-space"> <Kolb HKS Oil Cooler.jpg><Kolb HKS Exhaust A.jpg><Kolb HKS Exhaust B.jpg><Kolb HKS Exhaust C.jpg><Kolb HKS Exhaust D.jpg><Kolb HKS Exhaust E.jpg><Kolb HKS Exhaust F.jpg>
lambdinwilliam(at)gmail.c Guest
Posted: Sat Oct 15, 2016 5:46 pm Post subject: HKS Exhaust Andy Style |
That is a beautifully done exhaust job there😀 Bravo!
| Quote: | I created this stainless steel exhaust system from many pieces and manufacturers to fit within the limited parameters, the tube radii, expanded tube ends, and ball joints needed. I have this information if wanted. The system has not been tested for noise or vibration.
Andy
Kolb HKS Oil Cooler
Kolb HKS Exhaust A
Kolb HKS Exhaust B
Kolb HKS Exhaust C
Kolb HKS Exhaust D
Kolb HKS Exhaust E
Kolb HKS Exhaust F
victorbravo(at)sbcglobal. Guest
Posted: Sun Oct 16, 2016 9:47 am Post subject: HKS Exhaust Andy Style |
Wow Andy, now you have me REALLY interested in this style of exhaust. THANK YOU for taking time to post these photos.
Have you flown the airplane in tis configuration? It looks like the engine is mounted up on taller spacers, and then it also looks like tne engine mount plate is on smaller spacers above the rubber mounts too. Do I have this correct? Do you have pitch-down problems when you go to full throttle?
Looks like you have an external fuel filler on the port side of the fuselage. Nice looking
Is the oil radiator mounted on top of the square cross tube (between the main spar attach fittings)? Do you get enough cooling flow and good oil temps? That location (leading edgeof the wing) is acyually in low pressure when the wing is making lift.
I would VERY much like to learn more about your installation, it looks very clean.
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net      - winning proposals for non-profit and for-profit entities
On Sat, 10/15/16, Lanny Lambdin <lambdinwilliam(at)gmail.com> wrote:
Subject: Re: HKS Exhaust Andy Style
Date: Saturday, October 15, 2016, 6:45 PM
That is
On Oct 15, 2016, at 3:05 PM, Andy and Sheila Slinkard <andysheila(at)eltopia.com>
radii, expanded tube ends, and ball joints needed. Â I
vibration.
Andy
Â
Â
 Your
Kolb HKS Oil Cooler
Kolb HKS
Exhaust A
Kolb HKS Exhaust B
Kolb HKS Exhaust C
Kolb HKS Exhaust
D
Kolb HKS Exhaust E
Kolb HKS Exhaust F
<Kolb HKS
F.jpg>
