HA hub western flange.
ALEXGTPROPELLERS
PostPosted: Fri Oct 14, 2016 12:15 am    Post subject: HA hub western flange. Reply with quote
Calling all Yakkers, If you're currently using a Western prop flange on your M14 then consider that the Hartzell 3 blade hub can be installed using composite GT blades. The metal propeller on your HA hubs can be upgraded with advanced composite blades which offer many advantages over metal props. These blades are made to suite any size and model. See the example attached of a 500 HP ME109 replica using our custom 2.60/ 102” blades on HA hub.
Thanks for reading. Ciao Alex
PS 380 LYC/CONT conversions in service worldwide !
 Filesize:  366.86 KB
 Viewed:  2938 Time(s)
