Anyone have a B&C LR3b Voltage Regulator handy?
PostPosted: Tue Oct 11, 2016 5:13 pm    Post subject: Anyone have a B&C LR3b Voltage Regulator handy? Reply with quote
I have several such tools. Usually made
from a screwdriver with an 1/8" blade and
a short piece of .125" i.d. tubing glued
over the end.
An exemplar drawing calls the adjuster
out at just under 0.100" . . .
My guess is that the screw's head is about 1/8" in diameter but that is only a guess. Plus/minus 1/32" would do the trick. Thanks in advance!
[img]cid:7.1.0.9.0.20161011200954.049fcb80(at)aeroelectric.com.0[/img]
 Filesize:  49.82 KB
 Viewed:  1444 Time(s)
