lcottrell
Posted: Tue Oct 11, 2016 5:04 pm Post subject: Fwd: Re: More HKS Engine Interference Questions |
---------- Forwarded message ----------
From: Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)>
Date: Tue, Oct 11, 2016 at 6:51 PM
Subject: Re: Re: More HKS Engine Interference Questions
To: "kolb-list(at)matronics.com (kolb-list(at)matronics.com)" <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
Richard and Bill: here is the engine from all sides. Also included are some measurements from the cage to the Prop. It looks to me that a y'ed pipe coming out the back and down most of the way to the boom tube would be quite do'able. Bill If you try it out, keep me posted, I may want to take advantage of who ever does it for you for a pair of my own. I looked around a bit but could not find any pipe set ups that would trail the pipes down the back.Larry
On Tue, Oct 11, 2016 at 6:02 PM, Richard Pike <thegreybaron(at)charter.net (thegreybaron(at)charter.net)> wrote:
| Quote: | --> Kolb-List message posted by: "Richard Pike" <thegreybaron(at)charter.net (thegreybaron(at)charter.net)>
This particular thread has me really interested, even though I don't own an HKS. Larry; can you post a picture or two of your HKS on the airplane? Would like to see it.
1.41 MB |
2057 Time(s) |
1.4 MB |
2057 Time(s) |
1.43 MB |
2057 Time(s) |
lcottrell
Posted: Tue Oct 11, 2016 5:07 pm Post subject: Fwd: Re: More HKS Engine Interference Questions |
| Quote: | The placement of the muffler causes more problems than it solves. It screws up the wind needed to cool the engine, and slows the plane. I do not know if this engine needs a muffler? ( back pressure etc) If it didn't I would be thinking about collecting the two pipes in the middle between the cage and the prop having it come out below the boom tube. I would still put the oil cooler on the back of the cage however.
> You still may need to cover and funnel the wind over the cylinder heads, if so let me know because I have drawings of the cover needed for that.
> Larry
1.27 MB |
2057 Time(s) |
1.5 MB |
2057 Time(s) |
