Posted: Mon Oct 10, 2016 2:00 pm Post subject: Anyone have a B&C LR3b Voltage Regulator handy? |
I have 2 LR3bs installed on the firewall of my RV10 and need help. The
voltage output regulator screw is under a plastic cap on the unit. I
need the diameter of that brass screw's head.
The problem is that I need to adjust the voltage on one of the units but
I can't get a screwdriver on the head of this tiny screw because of
where the units are located. My solution is to fashion a screw driver
with a piece of brass tubing slightly larger than the screw to help
guide the screw into the slot.
My guess is that the screw's head is about 1/8" in diameter but that is
only a guess. Plus/minus 1/32" would do the trick. Thanks in advance!
Bill Watson
wgreenley
Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
Posted: Mon Oct 10, 2016 2:54 pm Post subject: Anyone have a B&C LR3b Voltage Regulator handy? |
I have one out I can check this evening.
On Mon, Oct 10, 2016 at 5:58 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
I have 2 LR3bs installed on the firewall of my RV10 and need help. The voltage output regulator screw is under a plastic cap on the unit. I need the diameter of that brass screw's head.
The problem is that I need to adjust the voltage on one of the units but I can't get a screwdriver on the head of this tiny screw because of where the units are located. My solution is to fashion a screw driver with a piece of brass tubing slightly larger than the screw to help guide the screw into the slot.
My guess is that the screw's head is about 1/8" in diameter but that is only a guess. Plus/minus 1/32" would do the trick. Thanks in advance!
Bill Watson
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
